NooTheme Premium WordPress Theme › Forums › Timetable › Classes not visible on timetable and strange time behavior when typing time
- This topic has 20 replies, 3 voices, and was last updated 7 years ago by
7 years, 1 month ago #1070384
quoted from code canyon:
Me
Hi, I just installed this plugin, but I notice some strange behavior when using the advanced scheduling option. I set a class time from 09:00 – 09:45, after I safe it, the time has changed to 11:07 – 09:45.When I put in al whole week of class times, I don’t see in on the schedule in the frontend.
Hi.
I think the issue from your timezone, please check your server timezone again. If yes, can you submit a ticket to our support site and give us your site info? We will help you check the issue soon.
Me
Hi, the timezone was indeed not set correctly (0 instead of +1 ) but this didn’t fix the issue. I notice the issue when I put in the time manually instead of using the time selector. If this is a known ‘bug’, please make it possible to enter time manual, this works way faster than scrolling in a massive time list.
Another issue: I don’t see my classes in the week calendar on the frontend. I’ve set an open date and filled 5 days with times of the class but it won’t show up. This is my shortcode in the page: [ntt_schedule item_limit=”0” min_time=”8:00:00” max_time=”22:00:00”]
please submit ticket...7 years, 1 month ago #1070385This reply has been marked as private.7 years, 1 month ago #1070462Hi,
You need to enter the field "Number of Week" (Repeat number of weeks on this class).
7 years, 1 month ago #1070541Hi
Thanks, this wasn't very clear for me.. I would like to get classes on a infinite time by default, by I guess I just fill in 999999 weeks.
Do you also have a solution for the manual inserted time?
7 years, 1 month ago #107054299999 weeks wasn't a good idea, the page crashed...
I've now set it voor 260 weeks (5y).
7 years, 1 month ago #1070582Hi,
You can put in the time manually but you must end after each entry with the "Enter" key.
7 years ago #1071067Hi,
Next issue, I’ve a class named Salsa & Zumba but the & character is not displayed correctly in the list view. It shows Salsa & Zumba. When I click it, it's display normally in de popup.
Also, the category is shown on mobile even when turned off in global and specific settings.
7 years ago #1071104Hi, i see the character code is automatically converted to & when I type "& # 0 3 8 ;" without the
spaces (see printscreen https://snag.gy/Zrtukf.jpg)
7 years ago #1071105Another thing.
When clicking on de < or > to view prev of next week, there's always a "No events to display" before showing the classes in week view. I don't have any events, is it possible to disable this?
7 years ago #1071239Hi,
This issue solved!.
I temporarily removed this text. I will check and update in the next version.
7 years ago #1071254Hi thanks for fixing the character issue. Is this something I can do myself next time?
Have you checked the category selectbox on mobile?
Last thing: If possible, I would like a dutch translation for "all category" and "with" trainer ("alle categorieën" and "met" )
7 years ago #1071323
1- For your issue, we also fixed it in Timetable plugin next version so you should follow us to update our plugin.
2- You can use Loco Translate plugin then translate your text. It still works fine in Timetable.
7 years ago #1071371Hi,
I'm receiving an error when updating the plugin from WordPress. "Bijwerken mislukt: Download mislukt. Forbidden" (Update failed: Download failed, forbidden)
I'm trying to use as less plugins as possible. I've tried editing the noo-timetable.pot language file but I don't see the changes in the site.
7 years ago #1071386Hi,
If you update the current version, any previous edits will be lost.
You can back up the fullcalendar.custom.js (/wp-content/plugins/noo-timetable/assets/vendor/fullcalendar-3.9.0/). Later, you update the current version and replace the content this file.
(If the update has problems, you can log in ThemeForest account and download the latest version and reinstall it.)
- WordPress doesn't read the .pot file but read .po file -> You need to compile the .pot file -> .po
You can use plugin Loco Translate. After the translation is complete, you can remove this plugin.
7 years ago #1071575Hi, what's causing (or better, how to solve) this issue with no events to display? This seems to be random, sometimes it shows the classes, sometimes it doesn't show anything at all and sometimes it needs a second or 2 to display the classes.
7 years ago #1071588This reply has been marked as private.7 years ago #1071630Hi, I removed the < date > perhaps this should fix it.
Is it possible that the amount of weeks (260) I set per class is to heavy?
7 years ago #1071690Yes, this will affect the query and load speed of the site.
7 years ago #1071693Ok, I'll set the weeks much less. Perhaps an idea for an update to just show a class and not having to set a starting date and a number of weeks to show? My client has a gym with a lot of classes who are always on the same day/time of the week.
7 years ago #1071695I've updated the plugin (and replaced fullcalendar.custom.js) but now the & is shown incorrect again.
Can you tell me how to fix this myself?
7 years ago #1071774Hi,
You can send me a screenshot to clarify.
I checked on this page: https://body-work.nl/lessenrooster/ and it still normal works.
You can remove the cache or try again with the anonymous browser.
