NooTheme Premium WordPress Theme › Forums › CitiLights › Citilights \ Footer Column #2 \ Featured Property Widget
- This topic has 13 replies, 3 voices, and was last updated 6 years, 10 months ago by
simontea.
6 years, 11 months ago #1071283
This widget should not include hard coded "For" before the status. Everywhere in the app you are using just status without "For" in pretext.
6 years, 11 months ago #1071322
Please find For%s in our language file, then you can edit it as your desire. In addition, please use Loco Translate plugin to translate it.
You can check, then feedback us.
Best Regards.
6 years, 11 months ago #1071374Hi Tracy,
I was able to find and change "For %s" and make it "%s" in widgets/citilights_widgets.php:105
However, before doing that I was trying to change it in noo.pot by inserting into
msgid "For %s" msgstr "%s" and it did not work.
I also installed Loco Translate and created en_US.po to change msgid "For %s" msgstr "%s" and it did not worked for me again.
May be I'm missing something?
Anyway, for now this issue is fixed, but could you please provide steps how can I prevent my change in citilights_widgets.php not to be overwritten with the next update or may be I still can do Loco text overwrite in order to remove "For" from the widget?
6 years, 11 months ago #1071405
That's very strange but we think that there was a little issue when translating. In case you should write your file to a child theme. Because it will be saved when updating our theme. Moreover, we also attached a Child-Theme package in our package on ThemeForest, you can install it and google it how to use.
6 years, 11 months ago #1071452Even though there is a way to fix this issue on case by case basis, are you planning to provide a fix in your software for future releases that removes "For" before the Status Name for this widget?
Thanks6 years, 11 months ago #1071527
Ok, we will discuss with our developer to remove "For" in Footer section soon.
6 years, 11 months ago #1071569Hi Tracy, thank you very much for considering removing this additional text from the widget.
Simon
6 years, 11 months ago #1071618
Posts: 3295ok, if you have any questions, don't hesitate to ask us. We are ready to help you.
6 years, 11 months ago #1072601Hi Tracy,
This issue has not been fixed in the latest release. Please confirm the status.
6 years, 11 months ago #1072613
We discussed with our developer to remove it and it removed from Citilights theme. Can you provide us with your website's URL & admin account and FTP account privately via checking Set as private reply checkbox?
We will help you to check it directly.
6 years, 11 months ago #1072813This reply has been marked as private.6 years, 10 months ago #1073231This reply has been marked as private.6 years, 10 months ago #1073285Yes, we have installed the Loco translate plugin, it will help you remove the For keyword, or change it to another keyword as you want.
6 years, 10 months ago #1073374Thank you very much for this trick, I've tested it on my working site and it works just great. Now I know how to use it in order to work around some text issues.
