NooTheme Premium WordPress Theme › Forums › JobMonster › Check BOX problem in he section
- This topic has 8 replies, 2 voices, and was last updated 7 years ago by
7 years ago #1069822
I have problems in check boxes,
There is many places have check box options in theme,
example:-
New Register
accept terms and conditions
applying a job
applying a resume etc...
all these places have check box and when i'll click that page is jumping and shows empty.
It's happens only in hebrew section.
7 years ago #1069962
it seems that this issue looks like this topic:
https://nootheme.com/forums/topic/some-general-settings/
Please follow it.
7 years ago #1069989This reply has been marked as private.7 years ago #1069994This reply has been marked as private.7 years ago #1070052
We are so sorry for the late response because we had a weekend so we cannot help you during that time.
1- For the issue related to click the checkbox when registering a new user, posting a job and posting a resume. The reason is the WPML plugin and we helped you to solve it.
2- Can you describe your second question clearly? Because we don't understand it clearly. If possible, please give us some described image. We will try to check then feedback you soon.
7 years ago #1070101Hi again,
First of all i want to make clear that,
what you helped to solve the problem is - 'query_var'=>error 404 (this is slug problems)
and
this ''check box problem'' i mentioned there but it did not ''solved'' there.
So ill make clear here that,
i still have check box problem in whole website in ''he'' section.
this problem is happening with all check boxes in website(in hebrew section only).
EXAMPLE-
its happening when ill post a job, at the end of the job form ''accept terms and conditions'' check box is there,
when ill check that its page is jumping.
ill attached here the example
i hope you understand my problem
thank you
7 years ago #1070128
We understood your question and we sent your information to our developers. They are checking this issue.
Then we will feedback you as soon as possible.
7 years ago #1070171Hi
Thanks for Your Reply,
Thank you for action
Waiting for positive answer.
Thank You
7 years ago #1070220
Our developer has got access to your website then fixed this issue.
Please check it again, then feedback us.
