NooTheme Premium WordPress Theme › Forums › JobMonster › Categories on single resume page on mobile (bug design)
- This topic has 16 replies, 3 voices, and was last updated 7 years, 2 months ago by
7 years, 2 months ago #1066427
As you can see https://prnt.sc/m2j6vq
on mobile the categories alignment is not correct. This is a bug. Can you please fix that, thanks
7 years, 2 months ago #1066428This reply has been marked as private.7 years, 2 months ago #1066451This reply has been marked as private.7 years, 2 months ago #1066501
We helped you to fix this issue by adding Custom CSS segment on Customizer > Custom Code > Custom CSS
@media (max-width: 480px) {.resume-table {
font-size: 12px;
.resumes .posts-loop-content table tbody td {
padding: 3px;
7 years, 2 months ago #1066514if I want to insert the code, it says that there is a mistake!!
in this section:
padding: 3px;
7 years, 2 months ago #1066515This reply has been marked as private.7 years, 2 months ago #1066576Yes, we have checked and fixed that issue on the mobile.
7 years, 2 months ago #10665937 years, 2 months ago #1066596Hi again.
Please check it again. We have checked and added the custom CSS to fix that issue on the mobile.
7 years, 2 months ago #1066597Its not fixed at all!!!! It still not the right alignment to the information above!!! Take your support seriously and don‘t do things just quickly!!!
7 years, 2 months ago #1066598See screenshot, this is not a well design. Take your support seriously!!
7 years, 2 months ago #10666317 years, 2 months ago #1066721see enclosed my feedback. I need revision
7 years, 2 months ago #10667617 years, 2 months ago #1066763This reply has been marked as private.7 years, 2 months ago #1066897Any update??
7 years, 2 months ago #1066957Yes, we have checked and fixed that issue on your site.
