NooTheme Premium WordPress Theme › Forums › JobMonster › Careerjet integration not displayed properly
- This topic has 7 replies, 2 voices, and was last updated 6 years, 11 months ago by
6 years, 11 months ago #1071847
Hello team, the page displaying careerjet API is not properly viewed .
There should be a text/display that first search box is Keyword and other is Location. In addition it should have place holder if someone removes the value from input box.
The same is issue as it is not properly viewable from Mobile headset also.
Please help for the same.
6 years, 11 months ago #1071892
Currently, we also support a text is Keyword and other is the location as your talk. You can go to JobCareerJet then delete example information of Keywords and Location option. You will have a front end as this image: https://prnt.sc/n86kjj
For the mobile view, it worked normally. Please tell us your issue which you met.
6 years, 11 months ago #1071948Please see my expectations as below.
The Job All type should be in parallel to other boxes and there should be provision to add help text as shown below.
6 years, 11 months ago #1071951
Posts: 3295This reply has been marked as private.6 years, 11 months ago #1072045Hi I believe the layout changes should not need any fees ,as the theme is good but such small points will definitely help to enhance the selling capacity and help other customers as well.
I am ok even this is available post few days.
6 years, 11 months ago #1072080
We also discussed with our developer about this then we decided to change the layout of it as your layout. Then it will be added to next version of Jobmonster theme. Moreover, we also quick-fix on your website.
Here is the example page:https://jobsdata.in/careerjet/
Please check it, then feedback us.Thank you.
6 years, 11 months ago #1072096Thanks for your understanding and support.
6 years, 11 months ago #1072112
If you have any questions, don't hesitate to create a new topic on our forum. We are ready to help you.
