Hello there! First of all, Im very happy with the plugin. By far the best and user friendly I bought. Well done 🙂
However I am facing a problem that I believe it's not related to your plugin, but the theme itself.
Im using HOURTY theme. it works with ELEMENTOR. And it has a widget called WPBINGO TABS that allows me to add custom html to each tab. It's linked to a section called WPBINGO TABS CONTENT that are like a normal html page you can update iwth Elementor.
When Im using Noo Before and After Plugin in the first tab (the one that loads with the page) it works perfect. But when I am trying to use it in the second or third tab, it doesn't appear.
I believe the website is not loading all the required components in hidden tabs.
Did it happen before to other users? I spent all day trying to fix it but my knowledge is very limited on this.
Thank you and congratulations again for your great work. I really hope it will work. I dont' want to use other plugins. This is the best 🙂
