NooTheme Premium WordPress Theme › Forums › JobMonster › Box Layout view does not show header images of pages
- This topic has 20 replies, 2 voices, and was last updated 6 years, 9 months ago by
miqbal.
6 years, 10 months ago #1074206
Dear Ma'am,
Your Box Site layout shows error and does not display "Header background Image". Header Image is not coming in Box Layout on all pages of the site.
Kindly see the screenshout in the attachment. and rectify the problem
6 years, 10 months ago #1074210This reply has been marked as private.6 years, 10 months ago #1074236
Yes, this is our issue. We added it to our list then our developer will fix it as soon as possible.
Please wait for updating our theme.
Best Regards.
6 years, 10 months ago #1074281Kindly rectify this problem when you next update your theme
6 years, 10 months ago #1074313
Yes, sure. This issue will be fixed in the next version.
6 years, 10 months ago #1074326This reply has been marked as private.6 years, 10 months ago #1074357
Posts: 3295This reply has been marked as private.6 years, 10 months ago #1074358You just fix it, but now the header image is not seem to be scrolling up inside the header image box while scrolling down as it does in Full width view.
Kindly check
6 years, 10 months ago #1074359
Posts: 3295This reply has been marked as private.6 years, 10 months ago #1074364This reply has been marked as private.6 years, 10 months ago #1074365This reply has been marked as private.6 years, 10 months ago #1074382
Posts: 3295This reply has been marked as private.6 years, 10 months ago #1074387This reply has been marked as private.6 years, 10 months ago #1074389This reply has been marked as private.6 years, 10 months ago #1074393This reply has been marked as private.6 years, 10 months ago #1074403DO NOT CHANGE WHAT YOU DID IN MY THEME IN YOUR NEXT VERSION.
You make Header Image STILL in order to make Box Layout Header Image visible. Now all HEADER IMAGES are becoming STILL and not scrolling with the page.
PLEASE DO NOT EDIT YOUR THEME IN YOUR NEXT VERSION what you did in this ticket.
I am now Backup Restore my website and from now using Full Width normal layout for the theme because your Box Layout is USELESS.
DO NOT EDIT YOUR THEME as you did in this ticket rather do other things.
6 years, 10 months ago #1074436I request you to kindly release your theme version with the Header Image in Box Payout problem sorted out WITH header images not being copied protection. As such now Header Images are not being copied in Full Width Layout and looking nice. I want the same Header Images also for Box Layout for Header images as it is now with Full Width Layout with image protection.
Kindly release and update your next version with this problem sort out.
6 years, 10 months ago #1074463
Thanks for getting back.
Please follow this topic to find out our answer: https://nootheme.com/forums/topic/job-location-is-missing-on-single-job-page/#post-1074462
6 years, 9 months ago #1076064Dear Ma'am,
6 years, 9 months ago #1076088
Can you provide us your information again? We will check it directly then feedback you soon.
6 years, 9 months ago #1076203Now I decided to use Full width view. No action required.
