NooTheme Premium WordPress Theme › Forums › JobMonster › Apply on Compoany Website directly
- This topic has 16 replies, 3 voices, and was last updated 5 years, 11 months ago by
6 years ago #1086486
There are situation when recruiter does not want candidates to apply or send resume to his/her email but he needs candidate to visit to company career page and apply through company recruitment platform..
"Apply for Job" & "Apply on Company Website" Button should appear and it should be optional such that either of both ways could be choosen by recruiters.
Please check if it is possible to impolement is upcoming updates or earlier.
6 years ago #1086493Hi,
Thank you for suggestions we will consider whether to do this function?
6 years ago #1086967Can I expect its implementation in coming updates?
6 years ago #1086975Hi,
We will do this function in the next updates
5 years, 11 months ago #1092786This feature does not happen in latest update. Till when shall I expect it?
I need it soon5 years, 11 months ago #1095984Hi,
What should I put text when the two buttons are displayed together?
5 years, 11 months ago #1095989For Normal Apply, where mail would be send to recruiter, we may use "Easy Apply" or "Quick Apply".
For Button which redirects candidate to respective job on Career page of company, we may use "Apply Now" button
I am taking this reference from Glassdoor5 years, 11 months ago #1096437Hi,
We will release this version next week. You can wait to update it.
5 years, 11 months ago #1098295Seems like this is not done in latest revision
5 years, 11 months ago #1099146Hi,
This function has been updated in the latest version. You need to enable custom application:
5 years, 11 months ago #1099213In this, either of the button "Apply | Go to Job" should be active at any time or option should be able to choose either or both of them while job posting
And instead of "Go to Job" it may have "Apply on Company Website".
5 years, 11 months ago #1101197Hi,
Users will not have the option rights. It is the settings from the backend, only adminstrator can set it.
You can use plugin Loco Translate to change it.
5 years, 11 months ago #1101208I have tried but I am not able to use Loco Translate plugin.
At any time, only One button should be available for candidate to apply. By default, it should be "Easy Apply" which would send application to recruiter's email or notification email given. If recruiter have given custom application URL, Button should be named as "Apply Now" and when candidate clicks on it, he would be redirected to custom URL page. At this time, application is not required to be send to recruiter.
Can you please modify in my website accordingly ? Thank you
5 years, 11 months ago #1103285Hi,
I added a function to custom the button text into functions.php of Child Theme.
5 years, 11 months ago #1103313Button text is fine now
Is it possible to dispolayt only one button (Easy Apply or Apply Now) based upon the field data. Only If user have entered custom URL, "Apply Now" button should be shown. If custom URL is not entered, only "Easy Apply" button is shown. Thus, at any time, only 1 button is shown.
5 years, 11 months ago #1105674Can I get any update on this?Can it be implemented?
5 years, 11 months ago #1107038Hi,
We will update this issue in the next few days. You can wait to update it.
