NooTheme Premium WordPress Theme › Forums › JobMonster › Add resume and job application are not working from wp dashboard.
- This topic has 13 replies, 2 voices, and was last updated 2 years ago by
Chaitanya HR.
2 years, 9 months ago #1220414
AnonymousInactiveTopics: 5
Posts: 16Hi,
We're facing an issue with adding a resume or adding a job application from wp dashboard, when I click from wp dashboard on "add new resume" or "add a new job application", it shows an error.
2 years, 9 months ago #1220415
Posts: 16This reply has been marked as private.2 years, 9 months ago #1220418
Posts: 16This reply has been marked as private.2 years, 8 months ago #1220424Hi.
For the add a new application, I have checked and found the issue from the candidate field in the new application. When you have a lot of users, it can't get all the users to these fields. I'll check and improve the source code to help you fix that issue.
2 years, 8 months ago #1220427Hi.
I have checked and fixed the issue on your site, now you can click to add new application at the back-end.
2 years, 8 months ago #1220433
Posts: 16This reply has been marked as private.2 years, 8 months ago #1220439
Posts: 16This reply has been marked as private.2 years, 8 months ago #1220444
Posts: 16This reply has been marked as private.2 years, 8 months ago #1220448Hi.
I have checked and disabled the debug log.
2 years, 8 months ago #1220449
Posts: 16Hi,
ok it fixed but when I click on add a new resume from dashboard it shows below error, similar to add job application issue.
2 years, 8 months ago #1220457Yes, Because the resume edit form has the field to select the candidate. The issue is when you have a lot of candidates. We will check and let you know soon when I found a solution.
2 years, 8 months ago #1220458Hi.
I have fixed that issue on your site.
2 years, 8 months ago #1220466
Posts: 16It's working now, Thank you.
2 years ago #1220971Dear Team,
We've trying to add new resume on our site using admin login, but it's showing error message "This page isn’t working".
Kindly support,
