NooTheme Premium WordPress Theme › Forums › JobMonster › 1) Jobs are not displayed Danilo
- This topic has 12 replies, 2 voices, and was last updated 3 months ago by
10 months, 2 weeks ago #1222530
Hallo Support Team,
We also have the problem that only twenty jibs are displayed in the customer view and there are many more jobs.
10 months, 2 weeks ago #1222531This reply has been marked as private.10 months, 2 weeks ago #1222532This reply has been marked as private.10 months, 2 weeks ago #1222533This reply has been marked as private.10 months, 2 weeks ago #1222540Hi.
We have checked and fixed that issue on your site. We also released a new version to fix that issue. You can get the update or keep the current version on your site.
10 months, 2 weeks ago #1222546Thank you for your quick help.
I have one more concern. On the mobile version of the website https://prace.starke-jobs.com, the typical red pin isn't visible in the Google Maps in job. However, it's there on the desktop version. It works perfectly on my other websites. Can you please check what the problem is?
best regards
Danio
10 months, 1 week ago #1222548Hi.
I have checked your site and found the issue with the option "Image optimization & CDN" on the Autoptimize plugin. It works fine when that option is unchecked.
I have set a static image for the map icon. It is bigger than the original icon.
6 months, 4 weeks ago #1222718Hello Support.
Since the 4.8.1 update, the frontend header has been duplicated. It looks terrible. I have another site with the same theme, and it's running version 4.8.0. There's no duplicate content. It affects the blog posts and the job listings.
You must be logged in to view attached files.6 months, 3 weeks ago #1222721Hi.
3 months, 2 weeks ago #1222889This reply has been marked as private.3 months, 2 weeks ago #1222897Hello.
With that issue, we need to enable the debug and check the source code. Please provide us with your site URL, admin and FTP account. We will access your site to help you check it soon.
3 months, 1 week ago #1222907This reply has been marked as private.3 months ago #1222909Hi.
I have checked your job posting function, and it still works fine. I can publish a new job or update the job.
