NooTheme Premium WordPress Theme › Forums › Mebla › Woocommerce price widget works too slow (readding)
Tagged: optimization, price widget, slow work, woocommerce
- This topic has 4 replies, 2 voices, and was last updated 6 years, 11 months ago by
6 years, 11 months ago #1071926
Hi everyone!
Woocommerce standart price filter widget works too slow, please see my screenshot:
Without cache: http://prntscr.com/n8lyia
With cache: http://prntscr.com/n8m2a9
It is a main website problem! We cannout use price filter, it is an actual problem! Need a help guys!
Other widgets work as expected. P.S. I am using top server with maximum speed.
Please visit my basic category https://teradom.ru/product-category/plitka/napolnaya-plitka/.
And run your test here.
Waiting for your reply.
Thanks!
6 years, 11 months ago #1071927This reply has been marked as private.6 years, 11 months ago #1071963Hi.
We have checked your site and found some issue.
1. Because your site also has a lot of products.
2. On the shop page, after filter the price it also filters another filter. https://prnt.sc/n90oko
As you see, on this link, it also needs to filter by another attribute.
After removed some filter, the filter price speed improved.
And one thing, you can try to use the CDN cache as Cloudflare, it also helps you improve the site speed.
6 years, 11 months ago #1071966Do we have a posibility to speed up price plugin ? May be to write custom price filter plugin ?
After removed some filter, the filter price speed improved. - not much, may be + 7 seconds for speed (30 sec - 7 seconds)
Do you have other recomandations ? It is a backend problem.
6 years, 11 months ago #1072229Hi again.
I don't have any other recommended. Everything is a default of WooCommerce, and we just custom the layout.
You need to know about the filter by the attribute on the shop page. When you filter the price, it needs to filter another attribute too, not only the filter by price. When you change one filter attribute, it will calculate another attribute filter value, please check it again, you will see filter attribute reduce when you change some another filter.
https://docs.woocommerce.com/document/woocommerce-product-search/widgets/product-filter-attributes/
That is why I recommend reducing the filter attribute.
