NooTheme Premium WordPress Theme › Forums › Timetable › Where do I generate a shortcode in Divi?
- This topic has 11 replies, 4 voices, and was last updated 4 years ago by
4 years, 7 months ago #1217863
I looked at the provided documentation and still cannot find where to generate the shortcodes for this plugin. I am using Divi theme.
I tried to do it using the WordPress Gutenberg builder but am not able to find the Noo icon/button in that. I cannot access the Classive WordPress builder.
Can you provide any insight? Thank you.
4 years, 7 months ago #1217873Dear, You can create Text Editor block in Gutenberg or Divi builder then use Shortcode generate button in editor (see attachment)
4 years, 7 months ago #1217891This reply has been marked as private.4 years, 7 months ago #1217894Dear, Please kindly sen for me admin account your site via private reply. I will check details to help you.
4 years, 7 months ago #1217902This reply has been marked as private.4 years, 6 months ago #1217930Hi again.
We found the jquery conflict on your site with our plugin. Please give us your FPT account. We need to debug the source code.
4 years, 1 month ago #1219146Hi,
I'm using Divi and I also can't find the shortcode that I can use to display the calendar. Where can I find the shortcode? Tried using the text editor on Divi but it doesn't have the Shortcode generate button in editor.
4 years ago #12192004 years ago #1219211This reply has been marked as private.4 years ago #1219216Hi karlooo.
You can create a page and use the default editor to create a shortcode, then copy the shortcode to the Divi page.
4 years ago #1219220Hi Jackie,
I saw what you did on the calendar. How can I make a month view of the calendar? The one you made is only good for a week. Also the link that you sent didn't load.
4 years ago #1219250Yes, please hover over the shortcode, click to noo icon, and it will pop up the modal config. Change the default view config to monthly. That will help you display the month view for the calendar. https://prnt.sc/oe8LnRQOo6iR
