NooTheme Premium WordPress Theme › Forums › Fitsica › Website not loading very well
- This topic has 39 replies, 2 voices, and was last updated 5 years, 2 months ago by
simo-br.
5 years, 3 months ago #1209557
Hi I installed the theme but I don't know my theme looks like this : studentslance.com
5 years, 3 months ago #1209610Dear, That problem because the demo data of Fitsica use Elementor old version, I don't understand why it not work with Elementor latest version.
To fix your problem: Please use WP Reset plugin to reset your site, then go to admin menu 'Elementor -> Tool -> Version Control' and 'Rollback Version' Elementor to version 2.7.5 then import data demo of Fitsica.
After import Fitsica demo data, you can update Elementor plugin to latest version.
Best reagrds.
5 years, 3 months ago #1209626can I give you my admin login and fix it for me ? and also the registration is not working as well I need this to be fixed as fast as possible . Thank you
5 years, 3 months ago #1209629This reply has been marked as private.5 years, 3 months ago #1209653This reply has been marked as private.5 years, 3 months ago #1209668This reply has been marked as private.5 years, 3 months ago #1209690This reply has been marked as private.5 years, 3 months ago #1209710Yes yes for sure
5 years, 3 months ago #1209740This reply has been marked as private.5 years, 3 months ago #1209753Dear, I check your site and is work well, your problem is resolved ?
5 years, 3 months ago #1209925yes it's solved but i have now some issues like the pages find a job or find a resume i didn't find them in all pages neither on addons , the other thing is the member dashboard where he can sent messages and manage jobs i can't find it either in pages so i could modify it .
5 years, 3 months ago #1209927for the pages i solved it but i won't get modified by elemantor otherwise where can I delete the archives and how can i modify the item showed in the company sidebar like "meta content"
5 years, 3 months ago #1209931I have another issue is while posting a job in the jobs page you find the job but when you click on the job to see more details it doesn't display you can check it can you please find for me a solution ( it's working on my phone ) , the other issue is the footer in the member dashboard it doesn't change while changing the footer in the customizer , in my phone I still have fitsica logo I don't know why please I need some answers as fast as possible .
5 years, 3 months ago #1209944Please consider this last message not the others
I've solved many problems that I face but I'm still have some trouble with :
* footer not letting the details of the job display very well .
* the member dashboard i have issues with the footer as well it the same issue plus i can't change the bottom bar
* the email me jobs like these in find jobs ( click on jobs in the menu ) not working .
* I can't change the header image of the pages my account , cart in the section shop
* if you know how can i setup mailchimp it would be great thanks .
5 years, 3 months ago #1209945the last that I will ask for is the menu I have the submenu of shop displaying under companies and i can't find where to fix it i tried with the customiser in navbar alignement but still have the same issue
5 years, 3 months ago #1209967* footer not letting the details of the job display very well.
=> I don't understand this problem, please kindly give me more details with screenshot.* the member dashboard i have issues with the footer as well it the same issue plus i can't change the bottom bar
=> I don't understand this problem, please kindly give me more details with screenshot.* the email me jobs like these in find jobs ( click on jobs in the menu ) not working .
=> Please add customm CSS code on your site to fix this problem.noo-footer-wrap{ z-index: -1; } body .site { z-index: auto; }* I can't change the header image of the pages my account , cart in the section shop
=> Please go to edit your page and add upload image for page setting 'Heading Background Image' (see attachment 1.png)* if you know how can i setup mailchimp it would be great thanks .
=> Please install and active MC4WP: Mailchimp for WordPress plugin on your site then go to 'Customizer -> Site Enhancement' and add Mailchimp API key, then you can use mailchimp widget.* the last that I will ask for is the menu I have the submenu of shop displaying under companies and i can't find where to fix it i tried with the customiser in navbar alignement but still have the same issue
=> Please go to edit Shop menu item and select sub-menu align left light attachment 2.png
best regards.
5 years, 3 months ago #1209977This reply has been marked as private.5 years, 3 months ago #1209979in single job post
5 years, 3 months ago #1210003it's solved I don't know how hhh can you provide me another plugin like front end pm for messages
5 years, 3 months ago #1210059This reply has been marked as private.5 years, 3 months ago #1210329I can't approve candidates from another account other then the admin like if a company want to approve someone else application it's impossible .
5 years, 3 months ago #1210331I have another issue ( attachement ) and the other thing is that the shortlist is not working .
5 years, 3 months ago #1210333This reply has been marked as private.5 years, 3 months ago #1210334for the last issue i can't modify this page with elementor
5 years, 3 months ago #1210392This reply has been marked as private. -
