NooTheme Premium WordPress Theme › Forums › JobMonster › Various Issues
- This topic has 20 replies, 2 voices, and was last updated 4 years ago by
4 years, 1 month ago #1219029
Pleas help with the following issues we are currently facing on the website:
- While on member page (either as candidate or employer), the profile completion percentage and and its text color is very light and not readable. How can it be changed?
- When candidate logins into the website, we want to show "Candidate Profile" instead of Member. However, for employer login, member heading is appropriate.
- Candidate is not getting Job Alerts for the alerts he has opted for.
- We want to add some custom menus in the member (for both employer and employee) login page. It already has its own menu like Post a Job, Manage Resumes, Shortlist etc.
4 years, 1 month ago #1219032Hello.
Please give us your site URL, admin account. We will help you check that issues.
4 years, 1 month ago #1219052This reply has been marked as private.4 years, 1 month ago #1219053This reply has been marked as private.4 years, 1 month ago #1219067Hi again.
Please check the admin account. It doesn't correct. We can't access to your site.
4 years, 1 month ago #1219069This reply has been marked as private.4 years, 1 month ago #1219086This reply has been marked as private.4 years, 1 month ago #1219088Now I'm unable to even login to my website. Can't you reply fast. It's been so many days that my complaint is pending with you.
4 years, 1 month ago #1219089Hi again.
We still can't access your website. Do you have to change something on your site?
Please let us know again and give us the FTP account. We need to access your source code.
4 years, 1 month ago #1219090That's what we are asking you. Even I'm unable to access the website.
4 years, 1 month ago #1219093This reply has been marked as private.4 years ago #1219101Please give us your FTP and admin account. We need to check the source code.
4 years ago #1219102This reply has been marked as private.4 years ago #1219107Hi again.
The FTP account returns an empty folder. Please check the account config again.
4 years ago #1219114This reply has been marked as private.4 years ago #1219120Hi again.
We have been able to access your back-end dashboard, maybe you have fixed that issue.
1. For the member front-end dashboard text color issue, we have added the CSS to help you change the text color to white. Please recheck it.
2. We have the option to show the Current Username for the front-end dashboard title, you can check it at the setting: https://prnt.sc/3WPpYXqM7MP3
3. Please give us the query for the job alert. We will help you check it again.
4. Please go to JobMonster/ Settings/ Member menu and enable the menu for the Employer and Candidate at the font-end. https://prnt.sc/LQE5HSVhzJJl
4 years ago #1219124This reply has been marked as private.4 years ago #1219170It's been 6 days that I asked for resolution for problems I am facing with your theme. But still I'm not getting any reply from your side. It would be great to if you will let me know whether you are capable to resolve my issues?
4 years ago #1219171Hi again.
1. We will create a job alert from my account to check the issue. We will check and let you know again.
2. We don't support the phone number on the registration form. So you can create a custom field for the Candidate or Employer account. That field will display on the user profile.
3. You can add more links to the front-end dashboard by changing the source code at this file:
wp-content/themes/noo-jobmonster/layouts/heading.php line 840.
4. You can use 3rd plugin as Loco Translate to change that string to another string as you want. https://prnt.sc/aaOXk5rLHUNI
5. As I see, the portfolio field type is an image gallery. So you can't upload PDF files to that field.
Please create another upload field and set the extension format is PDF. Then you can upload the PDF file. https://prnt.sc/bgWCGVnBHVyN
6. Sorry, we don't support type input for the Job Category field.
4 years ago #1219179For the third point, please share the coding that I can add by replacing the link and text.
Also, how can I add my custom icons for Job Categories. Currently, I'm restricted to the icons provided by the theme.
4 years ago #1219189Hi.
3.1 For the employer menu, add the code at line 843. https://i.imgur.com/MNmtx65.png
3.2 For the candidate menu, add the code at line 950. https://i.imgur.com/q0JIDdO.png
For the category icon, we use the library icon from this file: wp-content/themes/noo-jobmonster/framework/admin/assets/js/noo-iconpicker.js line 1069.
This is the icon from the font-awesome icon. If you want to add more icons, you need to change the source code and add the new icon library font to the back-end and front-end.
