NooTheme Premium WordPress Theme › Forums › Jobica › Various #2
- This topic has 40 replies, 2 voices, and was last updated 6 years, 2 months ago by
6 years, 3 months ago #1178113
Hi There
We’re getting an error when clicking the selected resume category X button. Please also see attached image.
Notice: Undefined index: s in /homepages/7/d744506797/htdocs/app744526229/wp-content/plugins/jobica-core/widgets/wp/widgets.php on line 2569
Some support here would be appreciated.
6 years, 3 months ago #1180669Dear, To fix you prblem. please delete Jobica Core plugin on your site then go to menu 'Appearance -> Install plugins' and install Jobica core v1.2.6 again.
6 years, 3 months ago #1181964This reply has been marked as private.6 years, 3 months ago #1184235Dear, if you want change it, please add custom CSS code on your site.
.result-filter-wraper .results-filter a:hover{ border-color: #81d742; } .result-filter-wraper .inner .filter-clear-all:hover, .result-filter-wraper .results-filter a:hover .close-value{ color: #81d742; }Best regards.
6 years, 3 months ago #1184781This reply has been marked as private.6 years, 3 months ago #1189143This reply has been marked as private.6 years, 3 months ago #1189195Dear, You can change 'Education', 'Work experience'.. via translate theme, Please use Loco plugin to translate Jobica theme.
best regards.
6 years, 3 months ago #1189861This reply has been marked as private.6 years, 3 months ago #1190159Yes, if you want change it in file, please switch your site to use Jobica child theme, then copy file 'wp-content/themes/jobica/layouts/resume/list_comment.php' paste to 'wp-content/themes/jobica-child/layouts/resume/list_comment.php' then you can edit text in file 'wp-content/themes/jobica-child/layouts/resume/list_comment.php'
6 years, 3 months ago #1190437This reply has been marked as private.6 years, 3 months ago #1192586Dear, in current version not support to disable text when hover review star, we're will check and to support disable it in next update version.
Also, i check review form on Jobica i see it still it display on mobile. but i can't see Resume review form on desktop to check. you not enable it ?
6 years, 3 months ago #1192875This reply has been marked as private.6 years, 3 months ago #1200341This reply has been marked as private.6 years, 3 months ago #1203445Dear, if review without logeed will cause spam problems and only Employer can write review for Resume.
Also, i see a problem when use Job type field with checkbox type, Please go to menu 'Jobica -> Custom Fields -> Jobs' and change Job type field to multi-select to fix your problem.
6 years, 3 months ago #1203452This reply has been marked as private.6 years, 3 months ago #1203898Dear, Please kindly delete Jobica Core plugin old version on your site then go to admin menu 'Appearance -> Install plugins' to install Jobica Core plugin v1.2.8 then check your site again.
6 years, 3 months ago #1204131This reply has been marked as private.6 years, 3 months ago #1204213Dear,To fix problem with Job Schema Posting, please kindly re-update Jobica Core plugin on your site to latest version 1.2.10 then check your site again.
6 years, 3 months ago #1204243This reply has been marked as private.6 years, 3 months ago #1204245This reply has been marked as private.6 years, 3 months ago #1204248This reply has been marked as private.6 years, 3 months ago #1204255This reply has been marked as private.6 years, 3 months ago #1204280Dear, when i check edit your home page with Elementor, i not see problem on home page like your attachment, please kindly check again.
6 years, 3 months ago #1204282This reply has been marked as private.6 years, 3 months ago #1204283This reply has been marked as private. -
