NooTheme Premium WordPress Theme › Forums › JobMonster › User Registration Problem, How to solve.
- This topic has 16 replies, 2 voices, and was last updated 5 years, 11 months ago by
6 years ago #1085786
Dear Support Team.
I have a problem as follow:
When registering as a new user with no use email confirm, it is Ok, then I try to create a resume and send to submit, one automatic email was sent from WordPress@domain to a user account, I try to change this email to my private admin email but it is said that not correct form, so I return to WordPress@domain email
When I change to use Confirm Email to create a new user, have no automatic email was sent to User Email, and no new user was created.
My Website: https://vieclamphothong.vip
You can try to create a new user to check, and please show me how to fix this. Thanks.
And Can I change the default EmailWordpress@domain email to my private admin email ?
6 years ago #1085801Hi,
- Change email: you go to Jobmonster -> Settings -> Email Tempaltes -> Other -> update 2 options From Email and From Name.
- Confirm register via email:
I signed up for an account, but didn't receive any email.
Are you using the mailing function from your hosting or from a 3rd party?
You can refer this post:
https://www.wpbeginner.com/wp-tutorials/how-to-fix-wordpress-not-sending-email-issue/
6 years ago #1086097Yes, by that way I did, but when I try to change email sent from to my private email It will notice email are not correct form, email correct form is xxx@domain, how to change to one another form of sent from an email which has no warning not correct form
No, I don't use email of Hosting,
Wordpress@domain email is the default email (sent from) send to the user account email when I trying post one resume to submit with Candidate User Account was created ( no email confirmed ). And have one automatic email send to User account email with WordPress@domain
I see many pages with extending have Elementor, and some page I don't see content to edit( may be when I install website using demo dummy content of Elementor,so it shows that )
6 years ago #1086098The refer link, it very useful to me to get to know more knowledge, but If the reason for WordPress cannot send email because of PHP function, I wonder why when trying post a resume to submit, one automatic email WordPress@domain was sent to User candidate email.
6 years ago #1086142Hi,
You can send me a screenshot of the email content the user receives.
You can use this plugin and config the site name, email for web to send mail.
https://wordpress.org/plugins/wp-mail-smtp/
5 years, 12 months ago #1086584hereunder is an automatic email sent when I try to post one Resume by a User Candidate Account ( created without email confirmed ) ( only once the first time, right now I try to send again but have no email was sent).
I try to solve it in some different ways, but the problem still exists.
WP Mail SMTP plugin
i try to set SSL with 465 port then TTL with 487 port
(email [email protected] is already created)
in domain setting register
I try to set CName ghs.googlehosted.com then
smtp.google.com
but have no way change problem.
in Jobmonster setting: email Template, from email: [email protected]
with From name
please show me next step to solve this problem.Thanks.
5 years, 12 months ago #1086588next ( attached screen shot)
5 years, 12 months ago #1086592next ( attached screen shot)
5 years, 12 months ago #1086596next ( attached screen shot) number 5
5 years, 11 months ago #1086863This reply has been marked as private.5 years, 11 months ago #1086940This reply has been marked as private.5 years, 11 months ago #1086941This reply has been marked as private.5 years, 11 months ago #1087040This reply has been marked as private.5 years, 11 months ago #1089233This reply has been marked as private.5 years, 11 months ago #1089481Hi,
Currently your send mail function is not working.
Can you check it again?
If your hosting supports "send mail" function. You can remove plugin WP SMTP and config smtp.google.com. I will help you check this issue.
5 years, 11 months ago #1089501I already asked hosting server support team, they tell me that it has no problem and they do not block email of my domain.
Your team are experienced in website design and deploy, can you detect the email problem of my domain, what is the reason of the problem.
I try to use WP SMTP and configure smtp.google.com because using the default email function of the theme do not work.
can you show me have any command to check where is the reason for the email problem?
5 years, 11 months ago #1089539Hi,
I deactivated plugin WP SMTP and use the function PHP send mail.
I install plugin Post SMTP and setup header for email on your site. With this plugin, you can check email log on your site.
- You can change the letter head, you go to Show All Setting -> Message tab
- Currently your email is sent to the Spam folder, you can refer to the article here to solve this problem:
https://support.google.com/mail/thread/2294985?hl=vi
