NooTheme Premium WordPress Theme › Forums › JobMonster › [[urgent]] Job management error
- This topic has 12 replies, 2 voices, and was last updated 7 years, 7 months ago by
Icaro Ferreira.
7 years, 7 months ago #1068387
Menu does not adapt to mobile resolutions.
follow print.
help!
7 years, 7 months ago #1068389This reply has been marked as private.7 years, 7 months ago #1068499
Your admin account doesn't correct so we cannot access your website. In addition, please give us your link directly because we don't understand your question when viewing your image.
Thanks so much.
7 years, 7 months ago #1068569This reply has been marked as private.7 years, 7 months ago #1068616
We have got access to your website then found that you have used the older version of Jobmonster theme & plugins.
Please update the newest version to get rid of this issue.
You can check again, then feedback us.
7 years, 7 months ago #1068659Hello, I have already made all the updates, but the problem persists, follow prints, just need to resolve this to get my site to work, please help me, I believe it is some defect in the responsive css for mobile, and only happens with the area of the employer.
Tks.
7 years, 7 months ago #1068687
Please tell us which devices you have used to check it?
Because we also checked your website on Iphone, it worked normally. Also, see the attached image.
Check it, then feedback us.
7 years, 7 months ago #1068707Hello.
I tested with work and I was normal but, the most free and visible work that will happen the problem, pay attention to the printed ones I sent, when some work / wave has been the layout gets normal, the error added.
7 years, 7 months ago #1068715I noticed the source code of the pages with posted work and no job posted, and the codes are very different, please please do the correction, the demo site of yours also faces the same problem, as the image follows, I will explain again: O PROBLEM ONLY APPEARS WHEN IT HAS NO POSTED WORK, BEING OBSERVED IN MANAGING VACANCIES / JOBS, IT IS A PROBLEM IN RESPONSIVE MODE FOR MOBILE.
TESTED IN VARIOUS CELLULARS WITH VARIOUS RESOLUTIONS, IPHONE, SAMSUNG, AMONG OTHERS
FOLLOW PRINTS OF THE SAME PROBLEM IN THE OFFICIAL DEMO OF YOU.
7 years, 7 months ago #1068777
We also got access to our website then checked this issue carefully. Then we found this was our issue.
In this case, we also added this bug to our list. After that, our developers are going to fix it as soon as possible.
Please wait for updating this issue in the newest version.
7 years, 7 months ago #1068831Hello!
And when will this new update be? Could not you solve my problem?
TKs
7 years, 7 months ago #1068876
Our developer fixed this issue on our website. If you want to quick-fix, please send us your information including your website's URL, admin account and FTP account exactly.
We will help you.
7 years, 7 months ago #1068913This reply has been marked as private. -
