I'll start by saying that support leaves much to be desired, I see no reason to renew.
The problem is in login / registration, when you select the option "forgot password" or "I already have an account" the modal is locked, and when you click to close, the page is cut successive times on the right side (following image attached), this problem also happens in the demo of you, I tested!
Before the problem I ask for help to change and install a login plugin that I found, where should I insert the shortcode and how to disable the native login / registration of the site?
Suggestion: Should replace the use of Iframe
