NooTheme Premium WordPress Theme › Forums › CitiLights › Upload Photos are looking thin and didn't upload.
- This topic has 13 replies, 2 voices, and was last updated 6 years, 8 months ago by
6 years, 9 months ago #1082595
When I try to add photos in submit property page, the photos looking thin and click to submit button, i get the upload at least 1 photo message.
6 years, 9 months ago #1082620Hi,
I'm not sure about this, you can load your site and try again.
If all else fails, please send me link your site and wp admin account. I will help you check.
6 years, 9 months ago #1082628Because of data security that I can't give you access password of the web site. Please can you check the php file that I attached.
6 years, 9 months ago #1082629May it problem with WP 5.3.2?
6 years, 9 months ago #1082674Hi,
You will need to select an image to use for featured image before add a property.
6 years, 9 months ago #1082704Hi;
the photos looking thin when I upload some photos! That is the real problem.
6 years, 9 months ago #1082706In addition, only one image can be uploaded, which is the featured image. Others do not upload. But I'm seeing on WP Gallery, unfortunately, they are not seeing on the property page.
6 years, 8 months ago #1082730This reply has been marked as private.6 years, 8 months ago #1082819This reply has been marked as private.6 years, 8 months ago #1082821How can I add the Property ID to the Property Detail Page?
6 years, 8 months ago #1082921Hi,
The gallery image is solved.
Can you describe more clearly?
6 years, 8 months ago #1082963Thanks for your effort. I got property id (post id) in the property detail page.
6 years, 8 months ago #1082964can you advise me a plugin for multi-currency?
6 years, 8 months ago #1083056Hi,
Woocommerce also supports many different currencies.
What is your using purpose?
