NooTheme Premium WordPress Theme › Forums › CitiLights › Unpaid objects are showing
- This topic has 9 replies, 2 voices, and was last updated 5 years, 5 months ago by
5 years, 6 months ago #1207700
AnonymousInactiveTopics: 6
Posts: 20I'm using the pay per submission model, but unpaid objects are shown on the frontend too.
5 years, 6 months ago #1207717Dear, Please kindly send for me admin account and your site URL via private reply, i will check details to help you.
Alo, I also need an account unpaid to check, please kindly send for me account have problem.
5 years, 6 months ago #1207846
Posts: 20This reply has been marked as private.5 years, 6 months ago #1207941
Posts: 20Hi!
Any updates on this?
5 years, 6 months ago #1207966Dear, I check again i see your problem because you Approval property on admin board because when submit new property, it will save with 'Pending' status (see attachment) please check your again.
Also, i see CitiLights theme on your site is outdate, please update theme and all plugin on your site again.
5 years, 6 months ago #1207980
Posts: 20Ok, so when something has the status 'Not Paid', but is approved it will still show up on the front-end?
5 years, 6 months ago #1207985Yes, if you 'Approval' via Admin panel, i will show.
On front-end, that property will change status when agent payBest regards.
5 years, 5 months ago #1208158
Posts: 20I'm sorry, but I still don't get it. What I would think is the following:
When I set in my admin settings that objects don't need admin approval it will still only show up once I pay for the listing on front-end.
Right now a property can have a 'not paid' status and still be shown on the listingspage.
So basically my users can create endless properties and not pay for them. That's not right is it?
5 years, 5 months ago #1208170Dear, If you want hide not paid properties on listing, please install and switch your site to use Citilights Child theme, then add custom PHP code in file functions.php of Citilight Child theme
//Hide not paid properties add_action('pre_get_posts', function(WP_Query $query){ if ( is_admin() || NooAgent::is_dashboard() ) { return; } if(re_is_property_query($query)){ $meta_query = $query->get( 'meta_query' ); if ( ! is_array( $meta_query ) ) { $meta_query = array(); } $meta_query[] = array( 'key' => '_paid_listing', 'value' => '1' ); $query->set( 'meta_query', $meta_query ); } });Best regards.
5 years, 5 months ago #1208172
Posts: 20That is perfect! Thanks!
