NooTheme Premium WordPress Theme › Forums › Palazzo › Unable to add / edit properties, Agentcs.
- This topic has 4 replies, 2 voices, and was last updated 6 years, 9 months ago by
6 years, 9 months ago #1082281
Hello Jackie,
Below error occurred post we updated plugins, please help. We are unable to add / edit properties, Agentcs.
Fatal error: Call to undefined function noo_get_user_role_in() in /var/www/vhosts/achieverproperties.com/httpdocs/wp-content/plugins/realty-portal-agent/includes/class-agent.php on line 560
Error Details
An error of type E_ERROR was caused in line 560 of the file /var/www/vhosts/achieverproperties.com/httpdocs/wp-content/plugins/realty-portal-agent/includes/class-agent.php. Error message: Uncaught Error: Call to undefined function noo_get_user_role_in() in /var/www/vhosts/achieverproperties.com/httpdocs/wp-content/plugins/realty-portal-agent/includes/class-agent.php:560
Stack trace:
#0 /var/www/vhosts/achieverproperties.com/httpdocs/wp-includes/class-wp-hook.php(290): RP_Agent::meta_box_agent('rp_property')
#1 /var/www/vhosts/achieverproperties.com/httpdocs/wp-includes/class-wp-hook.php(312): WP_Hook->apply_filters(NULL, Array)
#2 /var/www/vhosts/achieverproperties.com/httpdocs/wp-includes/plugin.php(478): WP_Hook->do_action(Array)
#3 /var/www/vhosts/achieverproperties.com/httpdocs/wp-admin/includes/meta-boxes.php(1549): do_action('add_meta_boxes', 'rp_property', Object(WP_Post))
#4 /var/www/vhosts/achieverproperties.com/httpdocs/wp-admin/edit-form-advanced.php(269): register_and_do_post_meta_boxes(Object(WP_Post))
#5 /var/www/vhosts/achieverproperties.com/httpdocs/wp-admin/post-new.php(75): include('/var/www/vhosts...')
#6 {main}
thrown6 years, 9 months ago #1082293Hi,
You are currently using a fairly old version of the Noo Palazzo theme. The above function may have been updated in a later version.
Currently you should revert to the previous version for the above plugin.
Then copy your website to a subdomain and update to the latest version. If there is no error on the subdomain update -> you will update it on the main site.
With the latest version, we have included all the functions into one plugin" Realty Portal" instead of using many plugins like the current version you are using.
6 years, 9 months ago #1082298Hi,
How should we do that? Since we have updated plugins, if we overwrite the same, will it delete our data?
Best
Ketan
6 years, 9 months ago #1082299Hello,
We tried reverting to older version, however, system is not allowing it to revert to previous version. Please could you help?
6 years, 9 months ago #1082322Hi,
First of all you need to make a backup of your website before updating the topic.
Updating the topic to the latest version (updating the source code) will not change the data in the database, but if you have any code changes in the parent theme they will be lost. You should back up the files you changed if any.
