NooTheme Premium WordPress Theme › Forums › JobMonster › Translation and others
- This topic has 6 replies, 2 voices, and was last updated 5 years, 12 months ago by
6 years, 3 months ago #1166164
Many a thing hard to accomplish with JobMonster...
For a start - I want to translate whole page from English to German. According to your Documentation it is suggested to use Loco PlugIn.
First thing I wanted to translate was the "enter job title" in your advanced search option (appearing on the homepage). Can't find the phrase in Loco... Next I wanted to translate the Job Categories in the same advanced search. Unable to do so.
I installed the demo, in order to demonstrate functionality to my customer - After a couple of adjustments in Customizer and Recruitment Home, some of the images are missing in the Job Categories section!?(Application Programming, Back-end Developer) and so on... They are missing both in Elementor and on preview.
Just some of the many bugs I am encountering. How am I supposed to turn this into a working and translated website I am wondering...
I already send you my admin - Please look into these things and let me know...
thanks
6 years, 3 months ago #1169253Dear,
1. Translate : please tell for me what is demo you use to import: WPBakery or Elementor ? because if you Elementor demo, you need translate theme and you must also translate text in Jobmonster Elementor Addon plugin. example 'enter job title' you can search in Jobmonster Elementor Addon plugin.2: Prevew: Please send for me admin account your site and your problem URL via private reply, i will check details to help you.
6 years ago #1207581Dear,
i am desperately trying to translate my website into German (beesocial.at). Using Loco Translate as suggested in Noo documentation. However, since I build the website using Elmentor, I am apparently supposed to translate the plugin as well!?
How exactly am I supposed to do that. Where can I find detailed instructions? I tried, but it doesn´t work and is frustrating.
Where is your tutorial on how to translate a site with Elementor? I looked everywhere. You stayed you are Elementor compatible. You state it`s possible to translate Jobmonster - so where is the documentation, the instructions to do so?
6 years ago #1207582For example - I wanted to translate
"Enter Job Title" from the search field.
Translating Theme - I don´t find it. (screenshot)
So I translated Plugin - where I found it and changed it. (screenshot)
However on the website it is still not translated. What am I doing wrong?
6 years ago #1207601Dear.
Maybe the document use screenshot of theme old version, in Jobmonster latest version not have string 'Enter Job Title' Please search text 'Enter a short title for your job'Best regards.
6 years ago #1207618I ask you a question and you don't even begin to answer it. Is this what you call support? It is so hard to accomplish anything, having to wait for a day and then not getting any real answers!
This really is unacceptable.
Answer my question as to how to properly translate the website plz.
I tried what you suggested - in plugin translate i cant find it / in theme translate I found it, translated, but still showing old text!?
5 years, 12 months ago #1207645I don't understand your problem because i see the Jobmonster on your site is use translated version ( see attachment) please kindly check your site again before complain.
