NooTheme Premium WordPress Theme › Forums › JobMonster › Translating Package
- This topic has 9 replies, 3 voices, and was last updated 7 years, 2 months ago by
7 years, 2 months ago #1066612
I have installed the plugin Loco Translate to convert the site to Dutch. However, this does not work with the package. (Step 2 when placing the vacancy: Days Membership, etc.) This remains in English. If I search for the words, they are not listed in Loco Translate. How can I convert this?
Thanks in advance!
7 years, 2 months ago #1066699Hello, can someone please answer my question?
7 years, 2 months ago #1066744Hi.
We have checked our theme, try to translate the Days, Weeks... in the package page. It still works fine.
Please go to the loco translate plugin, find the string with %d Days as this https://prnt.sc/m4q8xo
It will help you translate that string to another text as you want.
Do the same with another string Weeks, Months...
7 years, 2 months ago #1066770Hi Jacky, thank you for your answer. Unfortunately, the strings of the package page cannot be found in Dutch. See the attachment for my print screen.
Hope you can help me! Thanks!
7 years, 2 months ago #1066771<span>There are two other minor problems with me with Loco Translate. It seems that I can only change a text once. Then he does not take the changes anymore. See for an example in the attachments. </span><span style="color: #212121;font-family: arial, sans-serif">you can see that the text I entered at Loco translate does not match the text on the site.</span>
7 years, 2 months ago #1066772There are two other minor problems with me with Loco Translate.\
It seems that I can only change a text once. Then he does not take the changes anymore. See for an example in the attachments. You can see that the text I entered at Loco Translate does nopt match the text on the site.
7 years, 2 months ago #1066773the attachments
7 years, 2 months ago #1066838
We still found texts in your website. Also, see this image: https://prnt.sc/m56v5h
Note, you should choose this language file to edit: https://prnt.sc/m56vgc
7 years, 2 months ago #1066859Problem solved! Thanks!
7 years, 2 months ago #1066908
