NooTheme Premium WordPress Theme › Forums › Mebla › to cart
- This topic has 13 replies, 3 voices, and was last updated 7 years, 7 months ago by
7 years, 7 months ago #1068268
Hi, at the left and top of product image is a item of a card. In my website is also appear a text <to cart>.
How i can remove this?
Here is a screenshot https://prnt.sc/mj5adg
7 years, 7 months ago #1068403
Please give us your information again including your website's URL & admin account and FTP account privately via checking Set as private reply checkbox. We will check it issue soon.
7 years, 7 months ago #1068469This reply has been marked as private.7 years, 7 months ago #1068521
We have got access to your website then added this Custom CSS segment to remove text:
.woocommerce div.noo-product-item .noo-product-inner .noo-loop-cart .add_to_cart_button, .woocommerce div.noo-product-item .noo-product-inner .noo-loop-cart .product_type_variable { font-size: 0; }
it worked fine.
7 years, 7 months ago #1068528This reply has been marked as private.7 years, 7 months ago #1068534
We also got access to your website then checked coupon feature, it still worked fine.
For example, you can try this product: https://www.graphtype.com/product/premium-sample-pack/
Also, see these images: https://prnt.sc/mkfo8q and https://prnt.sc/mkfob6
Note, you should choose coupon code exactly for each product (which you configured in Dashboard)
7 years, 7 months ago #1068544This reply has been marked as private.7 years, 7 months ago #1068601Hi again.
With the coupon code, I think you have copied the space. Please check it again.
With the footer image, you can use the small image to replace the old image.
7 years, 7 months ago #1068625This reply has been marked as private.7 years, 7 months ago #1068627Hi again.
We found the custom footer at the child theme, please check the code at file
wp-content/themes/noo-umbra-custom/footer.php file
7 years, 7 months ago #1068646This reply has been marked as private.7 years, 7 months ago #1068665okay, we have added the custom CSS to help you reduce the image size.
7 years, 7 months ago #1068694This reply has been marked as private.7 years, 7 months ago #1068800
Posts: 3295ok, you're welcome
