NooTheme Premium WordPress Theme › Forums › Timetable › Timetable elements not displayed
- This topic has 8 replies, 2 voices, and was last updated 7 years, 6 months ago by
7 years, 7 months ago #1068819
Hey NooTheme-Team,
I really can't figure out why my timetable doesn't show all contents. Only monday seems visible. Please have a look at this, hopefully you can find the error. I will post my WordPress log in data in the next post.
7 years, 7 months ago #1068820This reply has been marked as private.7 years, 7 months ago #1068864Hi,
Please update the last new version for NooTimetable and WP Backery Page Builder and try again.
7 years, 7 months ago #1069517Hi,
thank you for the answer. I updated the NooTimetable Plugin but it still doesn't work. I don't know what the WP Bakery Page Builder should have to do with this. I added many classes which are not displayed for somehow.
A timetable which doesn't work is absolutely useless and harms my business. This really need to be fixed ASAP!
Hope to hear from you soon.
7 years, 7 months ago #1069587Hi,
Sorry for the delay reply.
I checked your site and the NooTimetable still normal works.
You need to set the field "Number of Weeks" for each class.
7 years, 7 months ago #1069695Hi,
thanks for this tip. I added this value to ever class but for some reason all classes are hidden in the timetable now. do you know why it acts like this? can you help me fixing it?
Thanks alot!
7 years, 7 months ago #1069736Hi,
The jquery error caused this problem.
It fixed, please reload your site and check again.
7 years, 6 months ago #1070298Sorry guys but this seems like it will never come to an end.
I added the category selection for all classes but for some reason the whole timetable is hidden again. And again I don't know why.
Can it really be so hard to get this working? 🙁 I'm sure this isn't a mistake made by me...
Thank you!
7 years, 6 months ago #1070473Hi,
The cause of this problem comes from incorrect coding of several characters in German. eg: Ü
Currently, this problem solved. Please reload your site and check again.
