- This topic has 1 reply, 2 voices, and was last updated 6 years, 9 months ago by .
Viewing 2 posts - 1 through 2 (of 2 total)
NooTheme Premium WordPress Theme › Forums › Palazzo › Theme Problems
In my properties page, i can't choose what is shown in "page title", even if i disable it shown Properties with breadcrumbs home - properties. I've changed the name of the page, and the options at the bottom of the page in "page title", and also try to disable the page title or breadcrumbs in the page or also in the theme options.
I also try to translate the theme with loco translate and to create a .po and .mo files with the .pot file in the theme but putting them in the child theme (i try also by putting them in original theme) but nothing worked : all my trasnlations doesn't appear.
This is not the first time i used payant wordpress theme and i never had this problems before...
I have also technic problem with updating new properties. I use all import with extension for properties by url's informations : title, photo thumbnail, content and custom fileds work good but i can't used the map because the software give city and not longitude/lattitude and i can't used gallery (i asked to import all images in _noo_gallery but it seems qui don't read good the information because it seems there are something but it doesn't show. More, i doesn't find where we can set the mortgage simulator that is shown on your demo.
Hope you can help me with all of this problems so i can did a pro website for my client and no regrets my buying.
Thanks, and sorry for my english (i'm french).
First, you should provide us with your website's URL, admin account and FTP account privately via checking Set as private reply checkbox. After that, we will check your issue.
In addition, as you said, you also got the issue of translation when you put your translation file to the Child Theme, don't you? However, please make sure that you have put it correctly. In case, please refer to this article for more details: https://nootheme.com/knowledge-base/avoid-losing-edited-language-files-update/
