NooTheme Premium WordPress Theme › Forums › Yogi › Theme installed and data importe
- This topic has 9 replies, 3 voices, and was last updated 6 years, 7 months ago by
6 years, 8 months ago #1077281
Hi Team,
I have imported and install demo data but site still not looking as it should also your installation guide is very confusing even for an experience developer.
Here is the link of the url with WP credentials:
Please resplve it ASAP...
6 years, 8 months ago #1077304
We helped you to configure some options on your site. In addition, we also imported our sample slider to your site so please check your site then feedback us.
6 years, 8 months ago #1077308I still don't see any changes, I only see what I have done.. Can you please recheck and see if the changes you made are reflecting in the current installation??
6 years, 8 months ago #1077327
Can you tell us the parts which don't look like our demo website? After that, we will check and help you.
6 years, 8 months ago #1077334I need it to look same as it looks in demo, we will change the image later before delivering it to the client...
6 years, 8 months ago #1077367
Currently, your website looks like our demo website exactly. I guess that you are focusing the gray images, aren't you? We have used gray images when you installed our sample because it will help you to easily change the images. Therefore, you should add your images to your website.
In addition, if you find out the differences as your demo website, please let us know, we will help you to check it.
6 years, 7 months ago #1078265I have created products but it's not showing in Shop section?
6 years, 7 months ago #1078267This reply has been marked as private.6 years, 7 months ago #1078355Hi team, waiting for your response...
6 years, 7 months ago #1078570Hi again.
As I see, maybe you have fixed the issue. https://prnt.sc/oxl22o
Please check it and let us know again if you still need the helps.
