- This topic has 1 reply, 2 voices, and was last updated 6 years, 2 months ago by .
Viewing 2 posts - 1 through 2 (of 2 total)
NooTheme Premium WordPress Theme › Forums › Palazzo › Theme Error (code lines, shortcodes
I have installed your theme and it has some errors.
1. compare is showing some code lines on top (screenshot attached)
2. after login user redirect on the page where simple short code is written. redirect page. screenshot attached
You can resend the screenshot. If it is PHP error, you can inlude the link your site and wp admin account (Set as private reply). I will help you check.
2. You go to Realty Portal -> Settings -> Member -> Redirect after Login -> select a page that you want.
