NooTheme Premium WordPress Theme › Forums › Mebla › Theme data (images) not avaliable
- This topic has 13 replies, 4 voices, and was last updated 7 years, 5 months ago by
7 years, 7 months ago #1068225
we have installed (Mebla - Multi Concept WooCommerce WordPress Theme) Home Page 6, link
theme is successfully installed but there is no data (images) available to import, only top slider images are available and banners are missing from demo.
As you can see in attached pictures that under |For Ladies| DRESS & T-SHIRT not showing and product images are also missing, and under FASHION NEWS blog images are missing
7 years, 7 months ago #1068402
We are so sorry for the late response because we had a long holiday for the lunar new year. Therefore, we cannot help you during that time.
Please provide us with your website's URL and admin account privately via checking Set as private reply checkbox. We will check this issue and import images on your website.
7 years, 7 months ago #1068463This reply has been marked as private.7 years, 7 months ago #1068519
You can go to our demo website http://wp.nootheme.com/mebla/ then download our images. After that, you can upload them to your website.
Normally, when you click to import our sample data, you will receive the gray images but it seems that there is an issue of the import process. Therefore, you can upload images by manual upload.
Please contact us if you still need to help.
7 years, 7 months ago #1068545This reply has been marked as private.7 years, 7 months ago #1068552Yes, we can give you the zip image but have different image ID with the dummy data image folder and origin site. That is the reason the image still can't link to correct folder when you updating the image folder.
7 years, 7 months ago #1068571This reply has been marked as private.7 years, 7 months ago #1068603Okay, this is link to download all image using on this theme
https://drive.google.com/file/d/14eAk2VBB_Y_P4Z3LcnVIZ-Kb0DTxU8lv/view?usp=sharing
7 years, 7 months ago #1068651This reply has been marked as private.7 years, 7 months ago #1068667
As we told above, you need to upload these images manually and add to position exactly. We are really sorry but we didn't have any option to upload once time.
7 years, 7 months ago #1068830This reply has been marked as private.7 years, 7 months ago #1068926
We are so sorry but you should upload these images by yourself because it is out of our support. In addition, when you start to configure your website, we think that you can change the image also.
In this case, if you still want to upload images we will help you will an extra fee.
Please consider, then feedback us.
7 years, 6 months ago #1071451This reply has been marked as private.7 years, 5 months ago #1071526
Posts: 3295Thanks for your feedback.
Firstly, please do not provide your information on another customer topic because it doesn't secure for you. We also deleted it and saved it to our list.
For your issue: We have got access to your website then checked it, you have imported our sample data successfully. Currently, we have used gray images in sample data. If you want to use our images, you can download the above link.
