NooTheme Premium WordPress Theme › Forums › Mebla › Stock Management Not Working
- This topic has 64 replies, 4 voices, and was last updated 7 years, 6 months ago by
7 years, 8 months ago #1067754
Hello guys,
I recently purchased your theme Mebla, I was initially using a theme and quantity in stock and out of stock are on product display page for each product. However, since i changed to your theme, the column has disappeared, i have checked every means, all to no avail, I learnt the issue was from your theme since other themes are showing the column.
Please, can you kindly provide the way out on that?
Also, i want to change the icon of my theme search on header to black and change to green on hover. I have checked all through as well to no avail.
My url is https://vascom.missionfistng.com/
Is there a css code that can be provided?
Your prompt response will be appreciated, as i have little or no time left on this project.
7 years, 8 months ago #1067758
1- For the issue of the column has disappeared, please give us your link directly so we can help you better. In addition, you would give us your images to describe this issue clearly.
2- You can add this Custom CSS segment to Customizer > Custom Code > Custom CSS to change the color of search page on the header:
a.noo-search{color:#040404 !important;}
7 years, 8 months ago #1067775Kindly check this screenshot attached. I have set the products stock in my product edit page backend. However, it is not displaying on the front end. I want the stock quantity i entered to display on the product page and as purchases are being made, it should be automatically deceasing so customers can see it. A;ll these were functioning before in my former theme before i changed to mebla.
Kindly assist further on this. Thanks,
7 years, 8 months ago #1067821
Please give us your website's URL & admin account and FTP account privately via checking Set as private reply checkbox. We will check your website directly.
7 years, 8 months ago #1067824This reply has been marked as private.7 years, 8 months ago #1067845I am still waiting for the prompt response for this. I am behind schedule on this project already.
Also, i need to change the image on my shop page banner, I couldn't change this, and also banner images across all individual products. Help with this info as well.
7 years, 8 months ago #1067910Hello,
Please I am wondering why its taking over 24hours to have a response on this ticket. i have stated earlier, I am behind schedule on this project. I need to deliver within the next 12hours.
i need response on this.
7 years, 8 months ago #1067981Hello,
I am quite very disappointed by the poor customer service I have received thus far. You guys refused to respond to my ticket since over 48hours, after which I specified I am due on this project delivery.
I am regretting already having to buy this theme.
This customer service is so pathetic, poor and saddening.
7 years, 8 months ago #1067985
We have transferred your question to our developer but please wait for us.
They need much time to check your issue.
7 years, 8 months ago #1067986I do not have much time at my disposal please. I am behind schedule on this.
7 years, 8 months ago #1067987Hi again.
We have checked your site, setup the stock product and it still work fine https://prnt.sc/me3e15
Please check it and let us know the issue again.
With the shop banner heading background, please go to customize/ WooCommerce/ Shop page, you will see the option heading background image.
7 years, 8 months ago #1067990For variable products, this is not showing
check
7 years, 8 months ago #1067992Even for this
https://vascom.missionfistng.com/product/foch-tile/
in your screenprint https://prnt.sc/me3e15
When for example 1000 products are added to cart, he value didn't reduce to 9000 from 10000. it should be decreasing automatically as customers buy them
kindly check and confirm.
7 years, 8 months ago #1067998For the variable product, you need to select the attribute to show the stock info https://prnt.sc/me42fs
The stock will reduce when the order complete.
7 years, 8 months ago #1067999Hello,
I don't want this to show by attributes. I want stock to be displayed without attribute. I want a single inventory stock for all attributes irrespective of selection.
Please I look forward to the response.
7 years, 8 months ago #1068000Hi again.
The stock using for all the attribute, but it only shows when you select the attribute, this is the logic of WooCommerce, not from us. If you want to always show the stock info on the variable product, you can add the custom CSS below
.woocommerce-variation.single_variation { display: block !important; }
7 years, 8 months ago #1068048Hello,
Please do you mean the css code you provided will enable the variable products stock to be visible irrespective of the attributes chosen? Kinldy answer please cause as it is, its still not showing.
Also, I am having an issue. I applied discount of 10% on all orders above 1000Euros (using dynamic pricing plugin), but also the this discount applies to only the individual cost and not the total cost on woocommerce cart page. However, the minimum order for a product is 1000 quantity. The discount applies only to the price for just "1" not for the "1000". Kindly see https://prnt.sc/me9dip
Can you assists in this?
And lastly, i have this message in my dashboard.
Your theme (NOO Mebla) contains outdated copies of some WooCommerce template files. These files may need updating to ensure they are compatible with the current version of WooCommerce. Suggestions to fix this:
- Update your theme to the latest version. If no update is available contact your theme author asking about compatibility with the current WooCommerce version.
- If you copied over a template file to change something, then you will need to copy the new version of the template and apply your changes again.
I need this fixed.
I hope for your prompt response.
7 years, 8 months ago #1068079Hi again.
With the stock display, I think you should set the default values like this https://prnt.sc/mem5vz
It will help you show the stock info at the first loading.
With the discount price, I'm not sure about the plugin, please contact the plugin author to check it again.
7 years, 8 months ago #1068080Can you give us the FTP account again? You forgot the server name.
7 years, 8 months ago #1068097This reply has been marked as private.7 years, 8 months ago #1068098Check the following links as well
Products columns sizes are way smaller here https://vascom.missionfistng.com/product-category/metal-products/
Than it appears here
https://vascom.missionfistng.com/product-category/plastic-products/
https://vascom.missionfistng.com/shop/://vascom.missionfistng.com/shop/
Kindly fix.
7 years, 8 months ago #1068134Hi again.
We have supported more layout for the shop product page, you can check the config at the Customizer/ WooCommerce/ Shop page to have the best layout for your site.
7 years, 8 months ago #1068139Hello,
Thanks for the support. I will really appreciate if this can be attended too before you go on ypur lunar holiday as i am late on this project delivery already.
I will love to request for something to be changed for me.
Kindly see the attached screenshots.
On screenshot, product 1020 is having quantity in stock show on the top left corner. I want this removed.
Also, I also want the stock quantity to display on the magnifier(quickview) and also below the price on the shop page.
Kindly assist as soon as you can. Thanks.
7 years, 7 months ago #1068401
We are so sorry for late response because we had a long holiday for the lunar new year. Therefore, we cannot help you during that time.
About your question, we cannot see your image. Please upload them to https://imgur.com/ then give us your link. We will check, then feedback you soon.
7 years, 7 months ago #1068428This reply has been marked as private. -
