NooTheme Premium WordPress Theme › Forums › CitiLights › Standard zoom with single property
- This topic has 16 replies, 2 voices, and was last updated 4 years, 10 months ago by
DirkS.
4 years, 11 months ago #1212609
Hi!
Is there a way to set the default zoom when there is only 1 property available? See: http://afdelingtest.nl/camping-te-koop/camping-resultaten/?location=frankrijk-camping&sub_location=normandie
Kind regards
4 years, 11 months ago #1212662Hello?
4 years, 11 months ago #1212720Could you please respond?
4 years, 10 months ago #1212839Hello? My question came in 2 weeks ago. If it takes this long to respond I would like to get at least a free extension of my support term...
4 years, 10 months ago #1212945Sorry, the Citilight not support you to do it, the theme with use default zoom setting in 'Map' setting for map on theme.
4 years, 10 months ago #1212946Isn't that the zoomsetting for the map on a single page? Because when I change that nothing happens in the searchmap.
4 years, 10 months ago #1212948Dear, I see you use zoom level 8, that not is your setting ?
4 years, 10 months ago #1212949No it is at 2 at the moment.
4 years, 10 months ago #1212951This reply has been marked as private.4 years, 10 months ago #1212954This reply has been marked as private.4 years, 10 months ago #1212955This reply has been marked as private.4 years, 10 months ago #1212956This reply has been marked as private.4 years, 10 months ago #1212962This reply has been marked as private.4 years, 10 months ago #1212963This reply has been marked as private.4 years, 10 months ago #1212982This reply has been marked as private.4 years, 10 months ago #1212987Dear, I check again and i see that is feature to fit all properties, if you want disable it, Please go to Map setting and un-check setting 'Automatically Fit all Properties '
4 years, 10 months ago #1213011But that is not what I want, I want it to fit all properties, but I just want to be able to set the zoom when only 1 property is shown, because that is zoomed in too much.
