NooTheme Premium WordPress Theme › Forums › JobMonster › Some translations (not avialable by Loco translate)
- This topic has 7 replies, 2 voices, and was last updated 6 years, 8 months ago by
6 years, 10 months ago #1075328
I would like in which file can i translate this:
http://prntscr.com/nvtf46And this:
http://prntscr.com/nvtgdgBest regards
6 years, 9 months ago #1075373
1- To translate: https://prnt.sc/nvtf46
Please follow these steps to change these texts via source code:- Step 1: Go to :{root}\wp-content\themes\noo- jobmonster\assets\vendor\DataTables\datatables.jsCopy all source code of this file to {root}\wp-content\themes\noo-jobmonster\assets\vendor\DataTables\datatables.min.js- Step 2: Search the text do you want to change. You can use the “Find”. Choose the key combination Ctrl-F and enter the word you want to search.- Step 3: Input the text that you want to change and save it.* For instance:-You want to change the phrase : Showing ... to ... entries, it located in line 11431.-Changed texts:You can use Loco Translate plugin then find this text in our language file and translate.Please check, then feedback us.Thank you.NooTheme6 years, 9 months ago #1075407Hello,
1. It's fixed! Thank You.
2. Cant find it in loco translate: http://prntscr.com/nx1orq
6 years, 9 months ago #1075434
Please go to {root}\wp-content\themes\noo-jobmonster\layouts\job\single\detail-style-2.php line 18 to change. Also, see the attached image for more details.
6 years, 8 months ago #1077134Hello,
Where can i edit this elements (i want to remove it): http://prntscr.com/oi1b96
I cant find it in
nor
detail.phpBest regards
6 years, 8 months ago #1077147
Please use this Custom CSS segment to remove it:
.noo-page-heading .page-title .count{display:none;}
6 years, 8 months ago #1077157Thank You! It's fixed. Problem resolved.
Best regards
6 years, 8 months ago #1077199
