NooTheme Premium WordPress Theme › Forums › Hermosa › Some Blog pages, blog categories and tag links are not opening
- This topic has 8 replies, 3 voices, and was last updated 7 years, 3 months ago by
7 years, 3 months ago #1076644
There are many Blog link that are not working. If we click on the Blog categories or blog tags, nothing is happening.
For example, from this blog post: http://quebecqigong.com/entrevue-avec-karen-mcdermott-de-la-formation-dinstructeur-de-qigong/
When you click on the link on the right sidebar, nothing is showing up.
7 years, 3 months ago #1076682Hi.
Do you have a server cache? We have changed the source code on the site but it doesn't effect.
If yes, please turn off the cache and let us know again. We will help you check it soon.
7 years, 3 months ago #1076704Hello,
May I know what have you changed in the Source Code?
It seem now that the Woocommerce as totally disappeared. I can't access Woocommerce on backend and my product are not linked anymore on the website:
http://quebecqigong.com/product/formation-instructeur-de-qigong-troisieme-annee-1er-versement/
Please advise, this is very urgent!
7 years, 3 months ago #1076705We are not using any server cache, everything is there inside the WordPress, You can test your code now and please help me to solve this asap.
7 years, 3 months ago #1076709Ok, Seem that someone dis-activated the Woocommerce. Not it's fine.
7 years, 3 months ago #1076729
We found out that the issue from your Child Theme. When we activated parent theme, the categories link works fine so please check your child theme again.
7 years, 3 months ago #1076754Ok, thanks.
Actually, the issu I'm experiencing right now is that I can't add some customize details on the Right Sidebar like I can do with the Classes post.
For example, on this Class post, I've used coding to add these details informations:
http://quebecqigong.com/classes/formation-instructeur-de-qigong-3e-annee/
Prix:2199$Please tell me how can I also do this for the Event post.
7 years, 3 months ago #1076755Prix:2199$Inscriptions hâtives: 2000$Réduit jusqu'au: 15 juillet 2019Contingentement: 207 years, 3 months ago #1076788
We found out that you have used the Custom Fields of ACF to build some custom fields for the Class post type. That's the reason why you have some custom fields when creating a class. Therefore, please try to create the custom fields for your Event as this image: https://prnt.sc/ocx10f
Please try to check it by yourself because this question is out of our support.
