NooTheme Premium WordPress Theme › Forums › JobMonster › Site Loading Problem
- This topic has 9 replies, 2 voices, and was last updated 3 years, 5 months ago by
joseph.
3 years, 6 months ago #1219129
Hi Noothemes Support, I don't know what happened. The job list next page loads is too slow or too long. It takes 10 seconds to 14 seconds to load the list. Can you improve it? Thank you!
Screenshot: https://prnt.sc/M3wPsqfrNYHA
3 years, 6 months ago #1219154Hi.
For that function, we use ajax to load more of the job when you click to next button. You can reduce the job to display on that shortcode or try to use the cache plugin as the Autoptimze plugin to improve that. Maybe that can help you.
3 years, 6 months ago #1219164we already enabled the Cache plugin with the godaddy and also installed another cache plugin to make it load faster. But still the same. We increase the job list to 20 and it took 14 seconds to load the next list. Did you have any solution to fix this problem? In Job board we can't reduce the list below 10 since we prioritize our user to browse more when the page is loaded.
3 years, 6 months ago #1219182Yes, let me try to reduce the data when loading ajax. Maybe that can help you improve the speed. Please wait for us, we will check and let you know soon.
3 years, 6 months ago #1219191Okay then. Thank you. I hope you update us as soon as you have already optimize the Ajax.
3 years, 6 months ago #1219226Hi.
We have checked the ajax function, it can't reduce the response time when you increase the job items.
We also reduce the content loading and check the query but it is not ok.
Maybe you should reduce the job items to 10. That will works fine.
3 years, 6 months ago #1219265Hello may I know on what particular file where the ajax is located? So that can I see it for myself. Thanks!
3 years, 6 months ago #1219266This reply has been marked as private.3 years, 5 months ago #1219309Hi Joseph.
I don't see the script file on your site, maybe you have used 3rd plugin to optimize the source code and script.
Please let us know again if you need help.
3 years, 5 months ago #1219322I already fixed the problem just today. I will share it with you. The problem is the WP Bakery. If you're website is too slow and you are using WP Bakery, much better is to switch to Elementor. WP Bakery a worse nightmare.
