NooTheme Premium WordPress Theme › Forums › Organici › shopping cart
- This topic has 8 replies, 2 voices, and was last updated 6 years, 2 months ago by
6 years, 3 months ago #1082500
In the nav bar top -- shopping cart, Is it possible to do a drop down menu like the picture?
I have a typography, could I load in the theme like a primary typography?
Best regards
6 years, 3 months ago #1082514Hi,
- Topbar mini cart: I added these lines to Custom CSS, you can reload your site and check again.
- You go to Customizer -> Typography -> Custom Font -> select your font
6 years, 3 months ago #1082516Could I move the search box and the cart in the navigation bar?
Im change the size of the Logo but it see same like always.
6 years, 3 months ago #1082560Hi,
I checked your site and logo still normal works.
You can remove the browser cache or try with anonymous browser.
- Because each header is a fixed style, you can't move the position, you can only show/hide it.
tb
6 years, 3 months ago #1082570ok with the logo, but Could I move the search box and the cart in the navigation bar?
6 years, 3 months ago #1082577Hi,
You can't move the position, you can only show/hide it.
6 years, 3 months ago #1082581Ok I wish show it in the nav bar menu like the capture. All in the same line.
Best regards
6 years, 3 months ago #1082585I have add other example
6 years, 2 months ago #1082619Hi,
I chose the Default Header and added these lines to Custom CSS.
@media (min-width: 992px){
.noo-header.header-1 .noo-main-menu {
-webkit-transform: translate(0, 0);
-ms-transform: translate(0, 0);
-o-transform: translate(0, 0);
left: 50%;
position: static;
.noo-header.header-1 .menu-position{
display: flex;
justify-content: space-between;
.noo-header.header-1 .noo-menu-option{
order: 3
.noo-header.header-1 .menu-position:after,.noo-header.header-1 .menu-position:before{
display: none;
