NooTheme Premium WordPress Theme › Forums › JobMonster › set a maxlenght on a custom field
- This topic has 11 replies, 2 voices, and was last updated 10 months, 3 weeks ago by
thierry.
1 year, 5 months ago #1222428
I have a custom field type "number", I want to put a minlenght and max with a pattern between 0 and 9
how to do itAttachments:
You must be logged in to view attached files.1 year, 5 months ago #1222453Hi.
You can use the select type for that field to set minlength and max with a pattern between 0 and 9.
1 year, 5 months ago #1222460Hi
Thanks for your reply, but where do I put this criterion? because I can't find it in the custom fields
Can you help me?
Thanks1 year, 4 months ago #1222477Hi.
This is setup for the select custom field: https://prnt.sc/tI_m30G4KzRz
1 year, 4 months ago #1222496hi
it's not a select I wantI want the visitor to be able to enter only numbers and I want to limit the length to 9 digits max.
Thanks1 year, 4 months ago #1222516Yes, please go to this file: wp-content/themes/noo-jobmonster/framework/libs/custom-fields/render-fields.php
line 88 with the function noo_render_number_field()
and change the input code from
<input id="<?php echo esc_attr( $input_id ) ?>" <?php echo $class; ?> type="number" name="<?php echo esc_attr( $field_id ) ?>" value="<?php echo esc_attr( $value ); ?>" placeholder="<?php echo $field_value; ?>"/>to
<input id="<?php echo esc_attr( $input_id ) ?>" <?php echo $class; ?> type="number" name="<?php echo esc_attr( $field_id ) ?>" value="<?php echo esc_attr( $value ); ?>" placeholder="<?php echo $field_value; ?>" oninput="javascript: if (this.value.length > this.maxLength) this.value = this.value.slice(0, this.maxLength);" maxlength = "9" />
This code will affect to all your number custom field.
1 year, 4 months ago #1222526hi
I've made the change to my LIFEN field and it doesn't work
the field isn't limited in length and I can currently put letters and numbers when I only want numbers.1 year, 4 months ago #1222542Hi.
Please recheck it. https://prnt.sc/Vqg8a4tCj1xB
I have helped you edit the source code on this site https://olivier3.idwebsolution.fr
Now it will limit the input length of the number field to 9.
1 year, 4 months ago #1222553hi
it's working
thank you very much
11 months, 1 week ago #1222800<pre id="tw-target-text" class="tw-data-text tw-text-large tw-ta" dir="ltr" style="text-align: left;" tabindex="-1" role="text" data-placeholder="Traduction" data-ved="2ahUKEwj4p4WVq8mQAxV3NvsDHVpOItsQ3ewLegQICxAU" aria-label="Texte traduit : I just updated my theme and WordPress, but the function that limits the number of entries to 9 isn't working.
Could you tell me what you did to make it work? It still works on the olivier.idwebsolution.fr version, but it no longer works on my new domain, olivier4.idwebsolution.fr.Please tell me if it's a file in my child theme or not, and which one in particular, because I don't see any difference.
Thank you, Thierry">I just updated my theme and WordPress, but the function that limits the number
Thank you, Thierry10 months, 3 weeks ago #1222823Hi.
I have checked your olivier4 site, and I don't see the custom source code for the number field type in this file:
If you want to limit the input for the number field type, you need to edit the source code in that file, lines 88 - 103. I have copied the custom code from olivier site to olivier4 to help you limit the field input.
10 months, 3 weeks ago #1222833<pre id="tw-target-text" class="tw-data-text tw-text-large tw-ta" dir="ltr" style="text-align: left;" tabindex="-1" role="text" data-placeholder="Traduction" data-ved="2ahUKEwjN5cLrnfqQAxXwNfsDHUXhH6sQ3ewLegQICxAV" aria-label="Texte traduit : That's good.
Thank you.">That's good.
