NooTheme Premium WordPress Theme › Forums › LandMark › Search not working
- This topic has 16 replies, 2 voices, and was last updated 6 years, 2 months ago by
6 years, 2 months ago #1204531
AnonymousInactiveTopics: 1
Posts: 9Hi!
We have updated the theme and the property search doesn't work. By one side, the personalized filter for area is not applying in the live results. By the other side, when you click the search button, it redirects to a blank page wothout any result. You can check at http://www.finquesmarcel.com
Waiting for your answer,
Pep
6 years, 2 months ago #1204596Dear, Please kindly send for me admin account your site via private reply, i will check details problem on your site to help you.
6 years, 2 months ago #1204645
Posts: 9This reply has been marked as private.6 years, 2 months ago #1204664Dear, i check your site i see a error in NOO LandMark Core 2 plugin, please delete NOO LandMark Core 2 plugin on your site then down theme package from ThemeForest to install NOO LandMark Core 2 plugin in folder 'Plugin Files' of theme package.
6 years, 2 months ago #1204684
Posts: 9Dear, I have done what you say and the filters are working, baut when you press the "SEARCH" button it takes you to a blank page.
Something is not running correctly.
Can you check it?
6 years, 2 months ago #1204685
Posts: 9Sorry, the surface filter is not working...
6 years, 2 months ago #1204695Dear, to fix your problem :
1. I check all page on your site and remove template setting of all page use template 'Property Search'2. Create new page with slug 'properties' like setting 'Property Archive Slug' in Realty portal Settings.
Now the search is display results, please check your site again.
6 years, 2 months ago #1204698
Posts: 9Hi!
Lots of thanks. The search button is working now, but the Area slider is not working. It doesn't mind where you move it, it always sho 85 properties.
By the other side, can we add filters to the search results 'Property Archive Slug' ?
Waiting for you reply.
6 years, 2 months ago #1204723Dear, I see the Area slider is working on your site, please see VIDEO
6 years, 2 months ago #1204732
Posts: 9Hi!
When we move the price slider, the number of properties in the map changes. When we move the area slider, the number of properties in the map shows always 85, and it only applies when you click on search. All the filters work on the live results except the area slider. Can you check it?
Please, give me also an answer about if we can add filters to the search results page to refine results.
Lots of thanks,
Pep
6 years, 2 months ago #1204733
Posts: 9Hi!
Here you can see in video how the area filter doesn't apply on map live results, as the other filters do: VIDEO.
Pep
6 years, 2 months ago #1204758Dear,To fix your problem, please delete NOO LandMark Core 2 plugin on your site then go to admin menu 'Appearance -> Install plugins' to install NOO LandMark Core 2 plugin again then check your site again.
6 years, 2 months ago #1204817
Posts: 9Dear,
We have deleted the plugin as you tell us to do. This is what we told us to do 5 days ago and we already did it. Anyway, we have done it another time and it's still not working. If you slide the area slider, it doesn't refresh the map (if you click the search button, the area filter is applying well). We expect the area slider works as the price slider, updating the map as you slide it. What is the problem?
Waiting for your answer.
Pep
6 years, 2 months ago #1204821Dear, i not see your site is use NOO LandMark Core 2 plugin latest version, i have help you to delete old version and update it to latest version 2.1.5. Now, please clear cache on your site and your browser to check again.
6 years, 2 months ago #1204825
Posts: 9Dear,
We have just checked and it's working. Anyway, we downloadad the plugin from theme forest, and we didn't have this last version. I will check it now again.
Now the filters are working fine, thanks. The problem is that the map appears moved in the page http://finquesmarcel.com/fincas/. I send you a picture that shows it. There is no css modified. In the home page it seems to be working fine.
Lots of thanks for your help.
6 years, 2 months ago #1204951
Posts: 9Hi!
Any news about the displaced map? Waiting for your news.
Pep
6 years, 2 months ago #1204964Dear, i have check your page and change to use page template and re-build page to help you. Now, please check your page again.
