NooTheme Premium WordPress Theme › Forums › JobMonster › Search function does not work
- This topic has 7 replies, 2 voices, and was last updated 2 years ago by
2 years, 1 month ago #1221365
Unfortunately we have a problem with our search function in connection with Google Maps.
When we enter a location in the search (it doesn't matter whether with or without a radius search), unfortunately neither jobs nor companies in this location are displayed, but above all in other distant locations.
If we enter a location in the search, it is not even taken into account, but some other location is automatically selected.
We urgently need help with this.Translated with DeepL.com (free version)
2 years, 1 month ago #1221366Hi.
I have checked your job map shortcode, you are using the address field for the search. That field only gets the correct job with the search address. It can't search addresses with the radius like the search field on the job sidebar.
Please check my screenshot: https://prnt.sc/sa6uw8YaoUJp
If you want to search address with radius, please use the field "Custom field: by distance" https://i.imgur.com/HrCEGkl.png
2 years ago #1221442Hello Jackie,
that works well and now the keyword search in the Maps map still has to work 100%. The search, which was integrated into the maps card, does not work at all and does not find the jobs even when entered!!!! We need help now!!!!
The customers are not happy about these errors and every time we have to wait a week for our request to be looked at, very good customers jump ship.
We have already had a programmer look at it and it would cost us an enormous amount of money to have it fixed.
The search in the maps card does not work even in the preview of Theme vorest!Please correct your bug as soon as possible.
In the last update, the author was also working on this map card search... I don't understand why I have to pay the support again to make the theme work properly... I don't mean any offense, but it would be nice if the author checked his work properly.
Is there a possibility that new features are announced in the update? I'm looking for a needle in a haystack after every update.
So I have the 2 things where 1. would be urgent to support.
1. keyword search in the maps card. I have attached an example!
2. documentation of updates.2 years ago #1221443I have attached an example
You must be logged in to view attached files.2 years ago #1221463Hi.
Please check the URL result for the search with the map:
The current longitude and latitude are the default values in the location settings and the distance is 5km. That is why you can't see any job in the 5km radius.
You can try this URL:
or with this URL:
You will see the difference.
I have checked and helped you change the current longitude and latitude values to 0. Now you will see the job result.
2 years ago #1221493Hello Jackie,
thanks for the help. I didn't expect this to be the problem, as it still worked at the beginning.
Is there a way to get an overview of what has been changed, optimized or adapted when updates are made to the theme?
Best regards
2 years ago #1221494Hello Jackie,
a second question, where exactly did you adjust this so that the search works? I would like to apply this in our test environment and have not found the change.Thank you
2 years ago #1221498Hi.
I have changed the source code in this file: https://jobs.localwork.de/wp-content/themes/noo-jobmonster/assets/js/min/job.min.js
You can copy that file to your test environment to check.
