NooTheme Premium WordPress Theme › Forums › CitiLights › Search bar not searching properties on IDX Broker
- This topic has 8 replies, 2 voices, and was last updated 6 years, 3 months ago by
6 years, 4 months ago #1196191
We have a search icon in the top nav bar, if you enter a property street name (ex. Barcelona) in the search field you are redirected to a page layout that looks very strange, is shows the Barcelona property and the other properties are shown behind the footer.
Then if you click "View Listing" it takes you to a 404 error. It appears the search icon in nav is not searching the IDX Broker properties.
Screen shots attached.
Thank you, Olivia
6 years, 4 months ago #1196326Dear, please kindly send for me admin account and your problem URL via private reply, i will check details to help you.
6 years, 4 months ago #1196571This reply has been marked as private.6 years, 4 months ago #1197384Dear, the page give 404 because your site not allow view listting on your site. When i go to admin Listings and check all Listings on your site, it give 404 page.
Also, to fix your problem when search page, please go to 'Customizer -> Header -> Navigation Bar' and check to 'Only Search Properties' to allow search only 'property'
6 years, 4 months ago #1199922Hello,
I've made the change to the Header > Nav > Only Search Properties, but now it won't recognize any property. When I search for Barcelona it gives me error "Nothing Found". See screen shot of where I edited the nav in Customizer.
What else can we try?
Thank you, Olivia
6 years, 4 months ago #1203743Hello, is there anything else we can do to fix this issue?
Thank you, Olivia
6 years, 3 months ago #1203913You have Barcelona in Property ? I search on admin i not see results.
Please kindly clearly:
1. The Barcelona is Listing on your site (not property)
2. If you don't check 'Only Search Properties' and search Barcelona it will display result but it give error 404 because the Citilights not support Listing style and the Listing not support view on your page, You can contact with plugin author to ask them.3. When you check 'Only Search Properties', mean only search on properties post type and search Barcelona but no results because your site not have property 'Barcelona'
6 years, 3 months ago #1204151Thank you for your reply, is there a way to search the Listings using the Citilights theme?
Olivia
6 years, 3 months ago #1204226Dear, please kindly contact with plugin author to help you fix it.
