NooTheme Premium WordPress Theme › Forums › JobMonster › Resume suggest for employers
- This topic has 35 replies, 3 voices, and was last updated 7 years ago by
7 years, 1 month ago #1068572
we purchased a licence for your plugin job Monster, and we want to restrict the Resume suggestion for the employers using several criteria for exemple : Adress, job name, Job category, skills, job experience and age in the same time to give for the employers the best Resume suggestion a qualitative one not a quantitative . Can you please help me to do these even if i should change the code.
Thank you,
7 years, 1 month ago #1068612
We discussed with our developer about your question but currently, they haven't found the best solution for your requirement yet. Thus, they will continue studying then add to Jobmonster theme in the future.
7 years, 1 month ago #1068626Hello,
so please, can you explain to me how the Resume suggest works???? because i found that the suggestions don't match the published job by the employers!!.
7 years, 1 month ago #1068652Hello,
We are looking for your reply as soon as possible,
repoted emergency about the Resume suggest for the employers because it doesn't work and our client is reporting for that, so would like please give us the solution to this problem.
Thank you,
it's very important.
7 years, 1 month ago #1068681
Please provide us with your website's URL & admin account privately via checking Set as private reply checkbox.
We will check your issue.
7 years, 1 month ago #1068713This reply has been marked as private.7 years, 1 month ago #1068750Hello,
We are waiting for your response about the previous request,
Thank you,
7 years, 1 month ago #1068793
1- We also got access to your website then helped you to enable Resume Suggest on your website. It worked fine.
Please see this link: https://www.jobs.recruitsolutiondz.com/member/resume-suggest/
2- For your second question, please give us an image to describe it because we don't understand your question clearly.
7 years, 1 month ago #1068816Hello,
First Issue ====> I'm sorry but you didn't understand my meaning, i didn't have a problem with showing the Resume Suggest, but it's not functionnal, for exemple i added a job in a specific category like : Computer science & internet but i had the Resume suggest for other catgeories of jobs like Civil Engineering, hotel and others that don't match with The job offer that i posted.
PS : We are really disppointed that you removed the content of the Employer & candidate Sub Menu and heading Menu, it's a website for a client and we have users that claimed about that. thank you for no deleting the content next time.
Seconde issue ====> we said that the Employer can't check the Candidate Resume and profil earlier, and he gets a page to login again, even if he is logged in . and now after that you changed something in the website he can't also see the Resume suggest he gets the login form again... it's a serious problem beacause even if he log in a second time he got the message that he is logged in alredy and need to refresh the page, but it doesn't work.
the picture showing the issue is in attachement .
7 years, 1 month ago #1068821I resolved the Seconde issue ====> "we said that the Employer can't check the Candidate Resume and profil earlier, and he gets a page to login again, even if he is logged in . and now after that you changed something in the website he can't also see the Resume suggest he gets the login form again... it's a serious problem beacause even if he log in a second time he got the message that he is logged in alredy and need to refresh the page, but it doesn't work. "
For the First it persists always, please help us to solve it.
7 years, 1 month ago #1068874
1- We understood your question and we discussed with our developer about it.
In this case, they need to review source codes of Resume Suggestion again. Please wait for us. We will check it again.
2- We didn't Delete anything of customer's website when we haven't received an agreement of customer. Please check it again.
7 years, 1 month ago #1068875
We also discussed with our developer about Resume suggestion. Currently, the query of resume suggestions is based on Job Location and Jog Category. That means it will get resumes near the company's location and category name.
Please check it, then let us know if you want to change the logic. We will review, then feedback you.
7 years, 1 month ago #1068902Hello,
thank you for your reply, but the matching as you said doesn't work correctly in my case,
i posted a job in a specific category like : "Internet " and i got Resume suggestions in another categories like "Hotel and other" that doesn't match the category job that i posted.
and yes i really want to change the logic by adding a matching by "POST NAME", "CATEGORY POST", and "JOB LOCATION"
Hope that you are going to help us to solve this serious problem.
in the attachmenet an exemple of the matching in my case that doesn't work.
7 years, 1 month ago #1068905if you need the FTP acces to verify the code that we have for the job suggestion we will give it to you?!! Thank you
7 years, 1 month ago #1068924
Currently, we also supported resume suggestion as your requirement (POST NAME", "CATEGORY POST", and "JOB LOCATION").
If you want to match resume suggestion correctly, you should redirect "job category" only.
Please consider, then feedback us soon.
7 years, 1 month ago #1068944Hello,
How can i redirect "job category" only? as you said.
i didn't understand.
7 years, 1 month ago #1068945I don't find where i can edit the Resume suggestions settings? can you help me to find it.
7 years, 1 month ago #1068992
If you want to receive "Resume Suggestion" based on Job category, we will help you to edit the source code. Because there is no option to make it in the Dashboard.
Please consider, then feedback us.
7 years, 1 month ago #1068993Hello,
Yes i want to set The Resume suggestion and the Job suggestion in the same time, based on Job category, location and Name if it's possible.
Thank you,
waitin g for your reply.
7 years, 1 month ago #1069033
It seems that you don't understand our answer clearly.
Currently, we supported to get Resume Suggestion by "Job Location" and "Job Category" but as you said "it isn't functional". Because, when systems find out Resume Suggestion based on "Job Location", maybe, this resume doesn't match "job category" which you want.
For example, you have a job category name: doctor but you are suggested resume name "teacher". It isn't wrong because maybe resume name "teacher" nears by your job location.
That's the reason why we asked you above. If you want to get resume suggestions based on "Job category" only. We will help you.
Please check our answer carefully, then feedback us.
7 years, 1 month ago #1069090Hello,
Yes please help me to get suggestion based on job category ...thank you
7 years, 1 month ago #1069205Hello,
i'm waiting for your feedback.
7 years, 1 month ago #1069281
We moved your requirement for our developer but they are so busy.
Please wait for us. We will feedback you as soon as possible.
7 years, 1 month ago #1069282
Posts: 3295Oh, in addition, please give us your FTP account privately because they need to get access to your source code.
7 years, 1 month ago #1069286This reply has been marked as private. -
