NooTheme Premium WordPress Theme › Forums › Jobica › Resume Custom Fields- Multiple select function is not working
- This topic has 16 replies, 5 voices, and was last updated 5 years, 11 months ago by
5 years, 12 months ago #1085534
Dears,
Please help to solve the Multiple select function is not working on resume Custom Fields.
(The remaining pages are not tested). Candidate choose the resume template and they can see the multiple select custom Fields, but when they finished the form and submit. The multiple select value didn't show on the final resume form.(already add the Custom Fields on setting to show)How can I solve it?
Please kindly help.
5 years, 12 months ago #1085675Hi,
We have just had 1 release for this issue. You can update it and try again.
5 years, 12 months ago #1085705I have same issues.
please show how to fix it .
5 years, 11 months ago #1085747Hi,
Please update the last new version.
5 years, 11 months ago #1085776How to update it ?
5 years, 11 months ago #1085784Hi,
To update directly on the site:
You go to Jobica -> Quick Setup -> add Purchase code
Later, you go to Dashboard -> Update -> update for theme.
5 years, 11 months ago #1085878This reply has been marked as private.5 years, 11 months ago #1085907still not working....
pls help
5 years, 11 months ago #1085922This reply has been marked as private.5 years, 11 months ago #1085963Hi ,
Did not get reply.
5 years, 11 months ago #1085970This reply has been marked as private.5 years, 11 months ago #1085986Hi ,
i can't see the private reply.
5 years, 11 months ago #1085991Hi,
You need to check here, please see image https://prnt.sc/rf41xi
5 years, 11 months ago #1086119This reply has been marked as private.5 years, 11 months ago #1086130Hi, @high767.
You are currently commenting on other users' topics, so they will see the information and comment content.
Please create new a topic and include your site and wp-admin account (Set as private reply).
I will help you check.
I'm not sure about this, usually you just need to update the purchase code. Then go to Dashboard -> Update or Appearence -> Theme and update the theme.
5 years, 11 months ago #1098265This reply has been marked as private.5 years, 11 months ago #1099129Hi,
We will have 1 release this week. You can wait to update it.
