NooTheme Premium WordPress Theme › Forums › Timetable › Repeated events are not repeated
- This topic has 11 replies, 3 voices, and was last updated 7 years, 5 months ago by
jojogym.
7 years, 8 months ago #1066345
Hi again.
Why is my repeated event not repeated?
On site http://www.jojogym.cz/rozvrh/rozvrh-2-1/, or http://www.jojogym.cz/rozvrh/rozvrh-2-0/ must be one repeated event in category 132 - "Taneční sál". But is not. This event is visible only on first date (20. 12. 2018), but when I set weekly repeating rulle, it not work.
7 years, 8 months ago #1066425How I can see, you have same problems with class (via this post #1059620) about 4 months. On your website is recurrence of events/class presented as one of primary function of your plugin. But stil have no solution for this problems?
7 years, 8 months ago #1066972Hi again.
We have updated the plugin to fix some issue about the repeat.
Please get this version and check it again.
7 years, 8 months ago #1067134No! NOthing changed.
I downloaded your last version of plugin and uploaded it to directory with plugins.
But nothing changed. When I create new repeated event, I will see it only first week. What issue did you fix? because, you have problems with importing repeated events from google callendar too!
7 years, 7 months ago #1067678Hi again.
We have updated the latest version 2.0.5.1 to help you fix the issue with the event repeat.
Can you check it again?
7 years, 7 months ago #1067713Hello.
Thank you. Now I can see repeated events. But!
When I use DIVI tab, I can not see time and name of event in calendar cell. (http://www.jojogym.cz/rozvrh/rozvrh-2-o/
7 years, 7 months ago #1067716And, repeaded event works only when I add it manually from WP. Repeated events is still not possible import from Google calendar.
7 years, 7 months ago #1068158Update: Your repeated events are not visible in calendar. I mean - text is not visible.
7 years, 7 months ago #1068432Hi,
Sorry for the delayed reply.
We are back after a long holiday - Lunar New Year.
I changed some code lines. Currently, the text is show, please reload your site and check again.
7 years, 7 months ago #1068439Hello, yes, text is visible. What about import repeated (recurent) events from GC?
7 years, 7 months ago #1068533Hi,
I check the import repeated event from GC and it still normal works.
I exported a .ics file and import to your site, you can view the below video:
https://www.youtube.com/watch?v=DYKaS2jI8II
7 years, 5 months ago #1070775Hello,
I had this problem because my ics file contained about 1700 events. So, I must split it by years and every year import extra. (many of events is repeated with start few years ago).
That is it.
