NooTheme Premium WordPress Theme › Forums › Organici › Read more button – change texts – Post Masonry Grid
- This topic has 7 replies, 2 voices, and was last updated 3 years, 11 months ago by
3 years, 11 months ago #1218231
Can you please let me know how to change the "Read more" string for the button that is Post Masonry Grid?
I was trying to find it in theme files but unfortunately no luck for now.
BR,
Petar
3 years, 11 months ago #1218233Hello.
To change the text string in our theme or plugin, you can use the Loco Translate plugin, and select the English for the theme language, which will help you change that string in our theme.
3 years, 11 months ago #1218239Hi,
The string that I want to change is not "View more", it's "Read more" and it's located in Post Masonry Grid.
Also, instead of using plugins, can you please share with me a specific file location where I should change it and replace it directly via cPanel upload?
Thanks in advance.
BR,
Petar
3 years, 11 months ago #1218252Hi again.
This is the shortcode of WPBakery Page Builder, you can use the loco translate to translate the language file from the WPBakery Page Builder plugin.
You should use that plugin to change that string. If you change the code, it will affect when updating the plugin.
Please try it again.
3 years, 11 months ago #1218261Hi,
Thanks for the additional feedback.
I am not able to locate the string "Read more" in the Loco Translate plugin. Can you please help how to accomplish this by providing repro steps and screenshots?
Thanks in advance!
BR,
Petar
3 years, 11 months ago #1218266Hi again.
Please find and translate the language for WPBakery Page Builder Plugin. https://prnt.sc/ksrKCEBjvEjk
Click to Loco Translate/ Plugins/ Select the WPBaker Page Builder. At the Overview tab, click on New Language/ Skip Template https://prnt.sc/vfZ6Nu4HRO_g then select english and select location system. https://prnt.sc/tzJelVAD8r7y
Then you can translate the string in the WPBakery Page Builder plugin.
3 years, 11 months ago #1218274Jackie,
Awesome - this is exactly what I needed. Thanks a lot for your kind support on this matter!
BR,
Petar
3 years, 11 months ago #1218284Yes, if you need help, please let us know again.
