NooTheme Premium WordPress Theme › Forums › Palazzo › Property custom fields translation
- This topic has 16 replies, 2 voices, and was last updated 6 years, 10 months ago by
6 years, 11 months ago #1080707
Hi!
How we can translate the values of the Property custom fields and display them properly on the site? ATM they are shown as translated in the WPML admin part, but are still show in english on site.
Thank you in advance for the assistance.
Regards!6 years, 11 months ago #1080710Also although we have entered information for the agents in English - they are still displayed in Bulgarian - assist with that as well, please.
6 years, 11 months ago #1080786This reply has been marked as private.6 years, 11 months ago #1080985This reply has been marked as private.6 years, 11 months ago #1081011Hi,
Please send me some screenshot where the text is having trouble translating.
6 years, 11 months ago #1081101Hi, we are having troubles in the whole property part - the footer, the properties, etc:
http://adis.nastop-bg.com/properties/%d1%87%d0%b5%d1%82%d0%b8%d1%80%d0%b8%d1%81%d1%82%d0%b0%d0%b5%d0%bd-%d0%b0%d0%bf%d0%b0%d1%80%d1%82%d0%b0%d0%bc%d0%b5%d0%bd%d1%82-%d0%bf%d0%be%d0%b4-%d0%bd%d0%b0%d0%b5%d0%bc-%d0%ba%d0%b2-%d0%b8%d0%b7/6 years, 11 months ago #1081212Hi,
I have been fixed the above issue.
Cause of this problem:
If you choose Bulgaria as the main language, you need to set the footer with the Bulgarian language in the theme option instead of english.
Later you go to WPML -> String translate -> translate footer id.
6 years, 10 months ago #1081237Hi,
thanks for the footer fix. Will have that in mind
what about the realty portal custom fields options - they are all in english - though we've translated using WPML.
Also the agent profile is displayed only in 1 language, though they are in both language.Regards
6 years, 10 months ago #1081361Hi,
I checked on the Palazzo theme. Currently these schools do not support translate with multiple languages. We will update this issue in the next version.
You can send me FTP account, I will customize the code.
Hope it helps!.
6 years, 10 months ago #1081552This reply has been marked as private.6 years, 10 months ago #1081608Hi,
I can't connect with the above info.
Please check again.
6 years, 10 months ago #1081619This reply has been marked as private.6 years, 10 months ago #1081636Hi,
I updated the code for property custom field.
- With agent profile, you go to wpml and select the domain "realty-portal" => translate for it.
6 years, 10 months ago #1081638Hi!
By property agent profile I mean - the agent info that is displayed in the property page.We have them translated .
Regards
6 years, 10 months ago #1081660Hi,
Currently 1 user will only be assigned to 1 agent.
Profile information is taken by userid instead of agent id => Agent will only support 1 language when displayed on the property.
6 years, 10 months ago #1081686is there any chance to have this changed?
6 years, 10 months ago #1081730Sorry, I currently have no solution to this problem.
Can you give me your WPML support account ?
I will create a topic hoping they can assist.
