NooTheme Premium WordPress Theme › Forums › Mebla › Product page > Horizontal tabs: do not work
- This topic has 9 replies, 3 voices, and was last updated 4 years, 10 months ago by Jackie.
4 years, 11 months ago #1074701
Product page horizontal tabs do not work. Could you please check?
4 years, 11 months ago #1074780
We are so sorry but we don't understand your question clearly. Can you provide us an image of "Product page horizontal" which you want to focus? After that, we will check on your site directly.
In addition, please don't publish your admin account because it won't secure for you. We also helped you to hide it.
4 years, 11 months ago #1075005Please see attached image.
You can see that the tabs are not displayed correctly and cannot be clicked.
You must be logged in to view attached files.4 years, 11 months ago #1075046Hi again.
We have checked your site and found the conflict with a 3rd plugin "Advanced Woocommerce Product Gallery Slider"
Please give us your site FTP account. We will help you check that issue again.
4 years, 10 months ago #1075364This reply has been marked as private.4 years, 10 months ago #1075389
Posts: 3295This reply has been marked as private.4 years, 10 months ago #1075399This reply has been marked as private.4 years, 10 months ago #1075529Hi again.
We have helped you check the conflict with that plugin. But on the next time, if you update the plugin, it will be lost the code. So you should contact the plugin author to fix the issue on the next version.
4 years, 10 months ago #1075611Thanks for your help.
What did you do so I can tell the plugin author to fix?
4 years, 10 months ago #1075769I just remember the issue from this file https://estoria.traderobotix.com/wp-content/plugins/advanced-woocommerce-product-gallery-slider/assets/js/wpgis.front.js
Please check it and let the author know the issue.
