NooTheme Premium WordPress Theme › Forums › JobMonster › Problem With Job Packages
- This topic has 12 replies, 2 voices, and was last updated 6 years, 2 months ago by
6 years, 2 months ago #1081435
So, I have created the job packages for my website and it is now showing up that something has gone wrong with website. The job packages do not show up to allow people to select one and when I go into the job packages from the back end and select one it is like the page is broken. I am not sure what to do. The packages do not show up in the process where the company is trying to post a job. PLEASE HELP!!!
This is what the broken link says on the back end. My website is Careeresl.com
Fatal error: Uncaught Error: Call to a member function get_downloads() on boolean in /home/customer/www/careeresl.com/public_html/wp-content/themes/noo-jobmonster/layouts/dashboard/manage-plan.php:39 Stack trace: #0 /home/customer/www/careeresl.com/public_html/wp-content/themes/noo-jobmonster/framework/admin/noo_member.php(1155): include() #1 /home/customer/www/careeresl.com/public_html/wp-content/themes/noo-jobmonster/framework/admin/noo_member.php(888): Noo_Member->_manage_plans_shortcode('') #2 /home/customer/www/careeresl.com/public_html/wp-includes/shortcodes.php(325): Noo_Member->noo_member_account_shortcode('', '', 'noo_member_acco...') #3 [internal function]: do_shortcode_tag(Array) #4 /home/customer/www/careeresl.com/public_html/wp-includes/shortcodes.php(199): preg_replace_callback('/\\[(\\[?)(noo_me...', 'do_shortcode_ta...', '[noo_member_acc...') #5 /home/customer/www/careeresl.com/public_html/wp-includes/class-wp-hook.php(288): do_shortcode('[noo_member_acc...') #6 /home/customer/www/careeresl.com/public_html in /home/customer/www/careeresl.com/public_html/wp-content/themes/noo-jobmonster/layouts/dashboard/manage-plan.php on line 39
There has been a critical error on your website.
6 years, 2 months ago #1081441This reply has been marked as private.6 years, 2 months ago #1081450This reply has been marked as private.6 years, 2 months ago #1081453This reply has been marked as private.6 years, 2 months ago #1081461This reply has been marked as private.6 years, 2 months ago #1081475Hi,
The website is not allowing me to change what is mandatory for companies to submit such as an actual address when posting a job or creating a business account.
You can send me some screentshot to clarify.
2, Display Package: You need to enable this function: Jobmonster -> Settings > http://prntscr.com/pycxbg
3, The button color will get from Primary Color: http://prntscr.com/pycymz
If you want to customize, you can add these lines to Custom CSS:
.navbar-nav li.menu-item-post-btn > a{
background-color: red; // replace red -> you color;
4, You need to add job post
5, It looks like this option is being wrong logically. You can now select "No" instead of "Yes".
6, You need to add testimonial list: http://prntscr.com/pyd8y9
and use the shortcode "Noo Testimonial" http://prntscr.com/pyd95j
6 years, 2 months ago #1081493This reply has been marked as private.6 years, 2 months ago #1081496This reply has been marked as private.6 years, 2 months ago #1081499Hi,
You need to uncheck this field:
- The color issue: Please disable the cache plugin, you should only be active it after you finish editing on your site.
6 years, 2 months ago #1081502This reply has been marked as private.6 years, 2 months ago #1081506Hi,
I change the color and this function still normal works.
Please remove the browser cache or try with anonymous browser.
6 years, 2 months ago #1081575This reply has been marked as private.6 years, 2 months ago #1081597Hi,
I added this option: http://prntscr.com/q0e0ew , the position changed.
There is currently no option to shorten the package content while keeping the current content as it is
