NooTheme Premium WordPress Theme › Forums › JobMonster › Post Resume – can uploading CV be made mandatory?
- This topic has 5 replies, 2 voices, and was last updated 6 years, 7 months ago by
6 years, 8 months ago #1076846
AnonymousInactiveTopics: 46
Posts: 55Hi,
When a candidate is posting a resume, is it possible to make uploading of CV a mandatory action?
rgds
hemant
6 years, 8 months ago #1076861
You can go to JM Jobmonster > Custom Field > Candidate> Find file_upload file then check Mandatory: Yes as this image:https://prnt.sc/odwv2s
6 years, 8 months ago #1076864
Posts: 55Hi,
Thanks for your reply. But I do not have that field file_upload fields in Candidate custom fields. I even checked resume custom fields, because this step of uploading the attachment appears while posting a resume.
pls check the attached screen shots of candidate and resume custom fields.
rgds
hemant
6 years, 8 months ago #1076929
You need to change the source code to make the Upload Attachment option is mandatory. Please replace this source code to {root}wp-content/themes/noo-jobmonster/layouts/resume/resume_general.php line 121
<?php if( jm_get_resume_setting('enable_upload_resume', '1') ) : ?>
<div class="col-sm-6">
<div class="form-group required-field">
<label for="file_cv" class="control-label"><?php _e('Upload your Attachment','noo')?></label>
<div class="form-control-flat">
<div class="upload-to-cv clearfix">
<?php noo_file_upload_form_field( 'file_cv', jm_get_allowed_attach_file_types(), noo_get_post_meta( $resume_id, '_noo_file_cv' ), '', 'required aria-required="true"' ) ?>
</div>
</div>
</div>
</div>
<?php endif;?>
6 years, 7 months ago #1077330
Posts: 55Hi,
Thanks for your reply. If I update the source code then I will have to re-do it everytime there is an update on the theme - am I right?
Actually, It would be great if you can provide this option in your next update as given in your screen shot: https://prnt.sc/odwv2s
regards
hemant
6 years, 7 months ago #1077352
You should write all your customization files to your child theme so it will keep them when you update our theme. In addition, we are so sorry but we won't add this to the next version because not all clients want to add it.
