- This topic has 4 replies, 2 voices, and was last updated 7 years, 4 months ago by .
Viewing 5 posts - 1 through 5 (of 5 total)
NooTheme Premium WordPress Theme › Forums › Palazzo › Palazzo Logo won't switch out in header 1
I've switched out the logos in the Noo theme options page, but logo continues to be on the Header 1 on the main page. How do I change this?
Please make sure that you have turned off the custom logo in your page. You should edit your page then check it again.
Thank you! Found the option
Can't find the location for editing the information in the top bar... It's not in the theme options nor appearance customization page.
You can go to Appearance > Widget > Top Bar Left then change the Custom HTML widget.
