NooTheme Premium WordPress Theme › Forums › JobMonster › package problem
- This topic has 6 replies, 2 voices, and was last updated 5 years, 11 months ago by
5 years, 12 months ago #1085757
i have a problem with my site, i want to use a package only for contact details, employer pay to see contact details.
for now, I cant even select the contact details package I don't know why. I want the employer to login and be able to see candidate details but not contact details before to see he will need to pay and see.
let me know if you help it urgent cause the site is already lives
https://smarthelperscenter.co.za/
i can provide login details
5 years, 12 months ago #1085794Hi,
Jobmonster has no separate package to use to view candidate contact details.
From the outset Job Package is only used for Post Job functionality.
- With these two options: these are additional options for the Job package.
Meaning: You will not be able to use the package option on these two options if the Job Package is not enabled on "Post Job".
I will describe how these options work width paid package:
- First, you will need to enable the Paid Package for 2 options.
- When you go to the job package will be able to this option:
===> The "View Resume" option with Employer paid package is just an option to the Job Package to limit number of "view resumes" that Employer can make.
5 years, 12 months ago #1085815Hi
I want to add a contact form on an individual candidate like: http://wp.nootheme.com/jobmonster/resumes/interpreter/
can you please guide me I to do that as you did on the link above
part2:
is it possible to suggest an employer a candidate manually?
show me if possible or suggest something else
5 years, 12 months ago #1085828Hi,
- Form is available. You only need to configure who can view contacts here:
- With user Employer, you can go to Resume Suggest item:
When a candidate posts a resume, they will need to enter Job Location, Job Category.
If these fields match a job from the Employer user, that profile will be returned in the Resume Suggest item.
5 years, 11 months ago #1086371Hi
if you check the screenshot you will see in grey are field that are disabled
it only happen when I choose something on the field, then others get disable I don't know why to please assist cause i did my best I can't see the issue
https://smarthelperscenter.co.za/member/candidate-profile/?candidate_id=66
try to register as a helper and in the form to edit profile you will see
5 years, 11 months ago #1086405Hi
5 years, 11 months ago #1086416Hi,
I think there may be conflicts js between plugin and theme. Do you have any other plugins installed besides the recommended ones?
If yes you can try deactivate it and try again.
