NooTheme Premium WordPress Theme › Forums › JobMonster › Package Payments
- This topic has 16 replies, 2 voices, and was last updated 6 years, 2 months ago by
6 years, 2 months ago #1082434
I am not certain what I am doing wrong, but I can't set up my payments for my packages? Whenever I am logged in as an employer, the page redirects to the home page again. Please help?
I will send temp editor credentials now for my backend in a private message.
Thanks!
6 years, 2 months ago #1082435This reply has been marked as private.6 years, 2 months ago #1082437Also, in addition to this, I want to edit the copy in each package (i.e. I don't want the list that is there by default, I want to add my own copy text there). How can i do this?
6 years, 2 months ago #1082461Hi,
Make sure you have installed the Woocommerce plugin and setup it (cart page, Checkout page ...)
- There is currently no option for you to add custom text to the package. But you can add custom fields to the package you want.
tb
6 years, 2 months ago #1082462This reply has been marked as private.6 years, 2 months ago #1082465Hi,
These are all default text, you can use Loco Translate plugin and update to your text.
6 years, 2 months ago #1082477Hi, another issue has not crept up... when I am in a new user screen and I select a package, it takes me to the third step to load the job post info.... but if I try to go back, it doesn't allow me to go and edit the package again. Neither the 'Back' Button nor clicking on Step 2 works. Please help.
6 years, 2 months ago #1082480This reply has been marked as private.6 years, 2 months ago #1082488Hi,
- If you choose the Free package (price = 0), the order will be automatically updated -> you cannot return to change the package. The back function only works when you select a package that costs > 0
- These packages revolve around the function "Post a Job" and "Post a Resume". So it will have default fields. If you want to change the text or hide these fields, you can use Child Theme and customize 2 files /noo-jobmonster/layouts/job/job_package.php and /noo-jobmonster/layouts/resume/resume_package.php.
- For the fields you added from Custom Field, you can change the field name in here:
6 years, 2 months ago #1082545Please help then with the code changes to hide the following fields? I am not a coding guru, but I have created a child theme to make the said changes, but I just need your help with the code in the layouts/job/job_package.php file? I want to hide the attached fields?
6 years, 2 months ago #1082549Hi,
- With 2 field "Post Job with Job Category field" and "Post job with job type field": You go to Jobmonster -> Custom Field -> Job tab -> uncheck option "Integrate Custom Field with Job Package".
- For the rest of the fields, I need an account with adminstrator privileges. I cannot customize the code with the above account.
6 years, 2 months ago #1082550Thanks, okay, have disabled the two fields in the Custom field section.
I have also now changed the rights on the user account to admin. Thanks again!
6 years, 2 months ago #1082552Hi,
I removed these lines, please reload your site and check again.
6 years, 2 months ago #1082554Thanks so much! Looks great, just one more thing, where would I change the order of the packages, i.e. from lowest price on left to highest on right?
6 years, 2 months ago #1082556Hi,
The issue has solved. Please reload your site and check again.
I added these lines to job_package.php file
6 years, 2 months ago #1082558Thanks so much, you have been awesome with the support!
6 years, 2 months ago #1082559Thank you.
I will close this topic. You can create new topic when having a new problem.
